  • With treble, middle, and bass adjustments capabilities, combined with central point positioning, you can easily find the perfect balance. Additionally, you can effortlessly defeat all the tone adjustments with just a click on the PURE button.
  • Unmatched Headphone Compatibility: Experience versatile connectivity with the Fosi Audio SK01 Headphone Amplifier Preamplifier 2 in 1. Its input features a 3.5mm line in, while the output offers a 3.5mm line out, along with a 3.5mm/6.35mm headphone jack. Enjoy powerful performance with a max power output of RMS 2400mW@32Ω, catering to terminating impedance between 16-300Ω. Elevate your audio experience with seamless connectivity and exceptional power, all in one compact device.
  • Tailor-Made Audio Experience: The SK01 is a multi-functional audio gear that caters to desktop and portable music playing and tone tuning. The tri-band adjustment allows you to personalize treble, middle, and bass, finding the perfect balance for your preferences.
  • Multi-functional experience: Whether as a powerful headphone amp, a customizable analog preamp, or an accurate equalizer, it effortlessly elevates your listening experience, delivering exceptional sound quality and personalized sound signatures.
  • Long-Lasting Battery: Enjoy up to 6 hours of continuous usage with the built-in high-capacity battery, while the isolated power design rejects interference, providing a pure listening experience without any interruptions.
  • Exquisite Design: Crafted with an aluminum alloy body, the SK01 is both elegant in appearance and touch, adding a touch of sophistication to your desktop setup.
  • What you Get: Fosi Audio Sk01 Headphone Amp x1, User Manual x1,2-in-1 USB Type-A/C to Type-C Cable x1, an 24-month worry-free warranty and friendly customer service.
SK01
Model SK01
Input 3.5MM line in
Output 3.5mm Headphone, 6.35mm Headphone, 3.5MM line out
Amp output maximum power High Gain: RMS 2400mw/ 32Ω,Low Gain: RMS 300mw/32Ω
THD+N 0.001% @ 1kHz and 770mV
SNR ≥108dB
Device Dimension 4.76*2*1.69inch (121*51*43mm)
Net Weight 0.641b/290g
Power Supply 5V, USB Type-C
Use a 5V 1.5A/2A adapter to charge it.
Item Quantity Fosi Audio Sk01 Headphone Amp x 1, 2-in-1 USB-A/C to C Cable x 1, User’s Manual x 1
SK01 User Manual
Based on 15 reviews
87%
(13)
7%
7%
Martin
Great little amp
The Fosi SK01 is a very capable little headphone amplifier. It is solidly built and has whisper quiet operation. The tone controls are effective, allowing the user to compensate for short-comings in their headphones if necessary. I found the 1/4" output produced a slightly stronger signal than the 1/8", but this might have more to do with the headphones (Sennheiser IE200) than the amp itself.
Paul C
Excellent for people with hearing loss
I have age-related hearing loss where I have decreased hearing for high frequency audio. This little amplifier provides very good compensation for this loss when used with my Sennheiser HD620s headphones. And at a very reasonable price.
Good buy in this cost
Worth it!
S R
This thing is crazy
If you want a pre-amp for headphone, this is way to go.
Paolo Prodan
Perfect companion
Fosi Audii SK01 is perfect for me. When i travel i can bring with me this little companion to adjust the power and the tone of my headphones... the internal battery is really a plus.
I'm very happy to have bought this amazing product !
