  • RMS 50watts x 2(8 ohms, 20 Hz - 20 kHz, 0.02% THD) for 2-16ohm speakers.
  • Similar to the HDAM circuit, adopts TOSHIBA 2SA1943 *2 and 2SC5200 as amplifier output chip to get HI-FI sound quality; Home HiFi amplifier, Sturdy, Aluminum enclosed amp makes it perfect for projects and DIY audio applications.
  • Tube Sound Quality: The JFET FET with the characteristics of electron tube is used as the single differential input and the output adopts the Large Current Darlington structure, which not only has a warm voice but also has powerful output; Exclusively designed for the customers who pursue HiFi sound.
  • 110V Powerful Power Supply: A-core non-breaking point oxygen-free copper ring transformer to get stable and powerful power input; We also have the AC220V Version. Japan Omron relay protection circuit; NOVER gold-mounted audio capacitors; Japan ALPS Potentiometer; All-aluminum chassis;
  • Manufacturer-Direct, free lifetime technical support, and 18-month manufacturer's warranty.
Fosi Audio HD-A1 Hi-Fi Home Class AB Power Amplifier
Model HD-A1
Output Power 50W x 2
Terminating Impedance 2Ω-16Ω
Input Mode RCA
Output Mode Speakers Output
THD ≤ 0.002%
Input Sensitivity ≤ 280mV
Power input AC 100-120V/AC 220-240V
Fosi Audio HD-A1 Amplifier x 1
AC power cord x 1
Video
Based on 2 reviews
50%
50%
Troy
One of your people dropped it and dented the corner before it was boxed and shipped. I know this because the packaging is in perfect condition.
Charles Blish
I love these amps
I have two in gold, been used for both a vinyl set up and to power sub outs from my AVR.. in any circumstance the sound is so pure and powerful, in a two channel set up sound stage is wide.. paired with the right gear they can handle anything you throw at them! Highly recommended
