$199.99
+ Free shipping
Audiophile-Grade Chipset Integrated
All-in-One Desktop Hub
Input: Bluetooth, COAX, OPT, USB
Output: 3.5/4.4mm Balanced Headphone Output, RCA
Quantity
Free shipping
Money-Back Guarantee
Customer support
$49.99
$49.99
Born for HiFi and Gaming
Poster
The K7 is a versatile gaming HiFi DAC/headphone amp, developed based on in-depth feedback from over a hundred HiFi and gaming enthusiasts. It supports mainstream digital inputs like USB, optical, and coaxial, and is equipped with aptX HD lossless Bluetooth codecs.
The K7 also features a microphone input with noise reduction, ensuring your voice is heard clearly online. Perfectly compatible with PS5 Pro, PS5, Switch, PC, Mac, tablets, TVs, and projectors, the K7 offers balanced headphone and line outputs. It easily handles music listening, gaming, work, live streaming, and multimedia needs. With its compact design and rich functionality, the K7 ensures an exceptional listening and gaming experience.
Reviews are in...
Poster
Poster
Why K7 DAC/Amp?
HiFi and Gaming,
Headphone Amplifier
Pure Music Enjoyment
Best Gaming DAC K7
Gaming Entertainment
Best Gaming DAC K7
Best Budget DAC
Best Budget DAC
DAC Bluetooth Amp
Comprehensive Digital Inputs
with Versatile Outputs
DAC Converter
3.5mm
Single-Ended Headphone Output
Rated Power
≥600mW+600mW @32Ω
4.4mm
Rated Power
≥2.1W+2.1W @32Ω
3.5mm
Microphone Input
Best Bluetooth Amp
Hi-Res
Bluetooth Codecs
Under 40 ms
Imperceptible latency
Lossless PCM 24bit/48kHz
Sampling Rate
1.5-Inch LCD
High Definition Display
User-Friendly and
Practical Control Design
Best Desktop DAC
Tactile Shortcut Buttons
Best Desktop DAC
Best Desktop DAC
Angled Ergonomic Design
Best Desktop DAC
Connection Diagram
All-Aluminum Alloy Body,
with CNC Integrated Design
Best Headphone Amplifier
Best Budget DAC
Best Gaming DAC
Fully Balanced Circuitry,
0.0002% Ultra-Low Distortion
Multiple LDO Regulators
Ensuring Clear Sound Quality
Application Scenarios
General Specs
Chipset
Maximum Sampling Rate
USB:PCM 384kHz-32bit/DSD256
Optical: PCM 24bit/192kHz
Coaxial: PCM 24bit/192kHz
Bluetooth:PCM 24bit/48kHz
Headphone lmpedance
16-300Ω
Firmware Upgrade
Bluetooth Version
5.0
Bluetooth Connection Distance
≤13m
Noise Floor
≤2.5μV
Input Voltage and Current
DC 12V 2A
USB Compatible
Devices
Audio Parameters
Rated Power Output
121dB
<0.0002%
Dynamic Range
121dB
Noise Floor
≤ 6.5μV
Rated Power Output
122dB
0.0005%
Dynamic Range
121dB
Noise Floor
≤2.5μV
Frequency Response
20Hz-20kHz (±0.1dB)
RCA Output
Output Level
≥2Vrms
20Hz-20kHz (±0.1dB)
0.0005%
Dynamic Range
121dB
Noise Floor
≤3μV
Frequency Response
20Hz-20kHz
Packing List
  • The microphone can only be used in USB input 1.0 mode, not in Bluetooth, optical fiber, etc; The microphone is not supported in RCA output mode, only in headphone output mode.
  • Because 2.0 supports higher sampling rates, while the sampling rate of the microphone is only 16bit/48khz. When playing high sampling rates such as dsd or 384khz, if the microphone is turned on at the same time, the two will conflict.
  • Not supported.
  • Yes, K7 has targeted the ambient noise frequency band and has processed it in an algorithm to make your call clearer.
  • After turning on the microphone mute function with one click, the other party will not hear any of your voice.
Based on 13 reviews
85%
(11)
8%
8%
Lisa Hernandez
Game Changing Audio Experience!
The Fosi Audio K7 is my first DAC/amp, and it completely transformed my gaming setup. I can now hear footsteps loud and clear, making it easy to pinpoint enemy locations with precision. The immersive sound detail gives me a real edge in competitive matches, and I absolutely love it!
Tristan Harmer
Great little amp
Exceeded all expectations, thanks :)
S R
Coolest looking DAC
No DAC looks cooler than this in this budget.
W Kovac
Swappable op amps
Please, make a version with swappable op amps that supports Sparkos op amps!
Giorgio Sgobba
5 stars are not enough
I've been using the Fosi Audio K7 for a week, paired with a Hifiman Arya Stealth. What can I say, almost perfection. Well-made and elegant DAC materials. Clean design and perfect size. For those like me who listen to music with Qobuz it's a must have. Do we want to talk about gaming? The difference compared to not having it is crazy. Adjustable highs and lows depending on the type of experience. Thanks Fosi. 5 stars more than deserved.
