HiFi and Gaming,
Headphone Amplifier
Pure Music Enjoyment
Best Gaming DAC K7
Gaming Entertainment
Best Gaming DAC K7
Best Budget DAC
Audiophile-Grade Chipset
Best Budget DAC
DAC Bluetooth Amp
Comprehensive Digital Inputs
with Versatile Outputs
DAC Converter
3.5mm
Single-Ended Headphone Output
Rated Power
≥600mW+600mW @32Ω
4.4mm
Balanced Headphone Output
Rated Power
≥2.1W+2.1W @32Ω
3.5mm
Microphone Input
Best Bluetooth Amp
Hi-Res
Bluetooth Codecs
Under 40 ms
Imperceptible latency
Lossless PCM 24bit/48kHz
Sampling Rate
1.5-Inch LCD
High Definition Display
User-Friendly and
Practical Control Design
Best Desktop DAC
Tactile Shortcut Buttons
Best Desktop DAC
Best Desktop DAC
Angled Ergonomic Design
Best Desktop DAC
Connection Diagram
All-Aluminum Alloy Body,
with CNC Integrated Design
Best Headphone Amplifier
Best Budget DAC
Best Gaming DAC
Fully Balanced Circuitry,
0.0002% Ultra-Low Distortion
Multiple LDO Regulators
Ensuring Clear Sound Quality
Application Scenarios
General Specs
Chipset
Maximum Sampling Rate
USB:PCM 384kHz-32bit/DSD256
Optical: PCM 24bit/192kHz
Coaxial: PCM 24bit/192kHz
Bluetooth:PCM 24bit/48kHz
Headphone lmpedance
16-300Ω
Firmware Upgrade
Bluetooth Version
5.0
Bluetooth Connection Distance
≤13m
Noise Floor
≤2.5μV
Input Voltage and Current
DC 12V 2A
USB Compatible
Devices
Audio Parameters
4.4mm Balanced Headphone Output
Rated Power Output
121dB
<0.0002%
Dynamic Range
121dB
Noise Floor
≤ 6.5μV
Rated Power Output
122dB
0.0005%
Dynamic Range
121dB
Noise Floor
≤2.5μV
Frequency Response
20Hz-20kHz (±0.1dB)
RCA Output
Output Level
≥2Vrms
20Hz-20kHz (±0.1dB)
0.0005%
Dynamic Range
121dB
Noise Floor
≤3μV
Frequency Response
20Hz-20kHz
Packing List
Based on 53 reviews
94%
(50)
6%
Sumanyu Janapareddy
A Nice Little Hub
Easily lets me switch inputs and outputs, and nifty OLED display
A.S.
Incredible Quality
What a value buy! I found this recommended by Joshua Valour and sure enough it did not disappoint in the slightest! Really elevates my headphones and the gaming experience!
Lesli Beier
I cannot find enough words to describe how amazing this dac is. It has been ten days since i received it and i have tested it to the maximum. I am very happy with my investment because it was worth every penny. The sound quality is insanely excellent. It works even better if you use an equalizer like apo on your pc. The built-in baxandall equalizer is also excellent. The device is very well built and you can feel the quality just by touching it. The casing is made of aluminum and it is very strong. For uac 2 mode i recommend installing the driver from their website. Their customer service is quick and efficient. My compliments to fosi store and company. Long life to fosi.
Marilu Bergnaum
Excellent product, absurd quality, simply the best DAC to have, used together with an edition from
Mavis Macejkovic
Good
