Exclusive DSP Algorithm
Exclusively tuned by Fosi Acoustic Team to maximize hardware performance while protecting the driver, delivering deeper, precise bass.
Smart Driver Protection
Equipped with DRC limiting technology to prevent overload during high-dynamic scenes.
More Powerful Bass
EQ1 mode delivers rich bass, ideal for an immersive entertainment and movie experience.
Faster Transients
EQ2 mode delivers precise bass, ideal for music and HiFi listening.
  • Deep and Powerful Bass: The innovative 10-inch down-firing driver design provides a smoother sound dispersion, paired with a 200W Class D amplifier (500W peak power) for stunning low-frequency performance. Whether for movies, music, or gaming, it delivers an immersive and impactful bass experience.
  • Stable Design & Rear Dual Bass Ports: Rear dual bass ports provide greater airflow, enhancing low-frequency output for fuller, deeper bass. The 14kg sturdy chassis effectively reduces vibration and noise, helping deliver clearer and purer low frequencies.
  • Compact, Modern, and Versatile: With a sleek 14.17 x 14.17 x 15.75-inch design and down-firing driver, the minimalist front panel blends perfectly with modern home decor. Customizable sound for movies and music, perfect for home theater, living room, or studio setups.
  • Exclusive Precision DSP Algorithm: Features DRC limiting to prevent overload in dynamic scenes. Built-in dual EQ modes allow sound customization, delicately reproducing the emotions and details of movies and music. Automatic signal detection saves energy by powering the subwoofer on and off intelligently.
  • Flexible Connectivity and Control: Supports both LFE and RCA inputs for seamless integration with amplifiers and receivers. RCA output allows expansion with additional active subwoofer or amplifier. Equipped with 0°–180° phase adjustment and a 40Hz–180Hz precise crossover for accurate frequency separation and perfect alignment with main speakers, delivering cleaner, deeper bass.
Based on 5 reviews
100%
(5)
Gary
An immediate improvement
I did not expect to see these so soon!!!
I submitted the subwoofer feedback survey back when Fosi was asking and they released something nearly identical to the specifications I suggested. I felt obligated to buy them because of how good of a match they are! I bought two because they were half the price point I expected with the spec.
For comparison, I used two Dayton audio SUB-1200s. They were $199 each and have front firing 12s with 100w amps. They felt considerably underpowered and I had phasing issues due to their location and lack of adjustability.
Out of the box the Fosi subs are crisp, compact, and very clean cut. I do not like the white. Why it is the first and only color available is surprising. I am considering ways to refinish these soon.
I'm only a couple of hours into break-in and these are much more impactful than what I replaced. The down-firing driver makes a drasticly increased tactile experience.
Musically, they're very clean and easily fill a 16x20 room.
I have yet to listen to them in surround sound, which is a secondary purpose for me.
I estimate with 100 hours or so of break-in and fine tuning phase, crossover points, and port direction, I am going to be a very happy camper.
Max
The right complement to my Fosi SP 601 loudspeakers
Already preordered at a very deal price ! Waiting for delivery as a baby in front of a piece of cake ! ;-)
Deric
suggestions
i would same buy 2x discount from 1. also add passive radiator instead 2x ports. different colors offered more than black and white rest sounds good.
Joe Kelley
Black?
Looks good but I would like to see option for black and a deeper discount on two maybe $500
Doc House
The white cube
new sub
if the Egyptians had such sound tools, like the Fosi cube and the other gadgets , they would've built the pyramides in half of the time
Thank you Fosi
Pat
Bavaria
