  • Adopt Texas Instruments TDA7498E chip, NE5532 op-amp. No pop, no audible noise, dead silent when nothing is playing through it;
  • Built-in low pass filter, 220W X 1(4 ohms, 20 Hz - 120Hz, 0.04% THD, 18db/octacce) for subwoofer, Small simple compact design but practical and powerful;
  • Advanced circuitry design, built-in speakers protection circuit, solid aluminum chassis for long time use;
  • The new version of TP02 has one more sub freq adjustment knob than the old version, and the others remain unchanged.
Quick tips:
Model TP-02
Output Power 220W for Subwoofer
Terminating Impedance 2Ω-8Ω
Input Mode RCA
Output Mode Passive Subwoofer /
Powered Subwoofer
Frequency Range 20-200Hz
THD ≤ 0.04%
SNR ≥ 98dB
Input Sensitivity ≤ 280mV
Device Dimension 5.12 x 3.54 x 1.58 inches
DC Input Range 12-24V
Power Supply 24V 4.5A
Fosi Audio TP-02 Amplifier x 1
AC Power Cord x 1
24V 4.5A Power Adapter x 1
Compare with similar items:
