  • VOL20 *1
  • USER MANUALL *1
Based on 38 reviews
66%
(25)
18%
(7)
11%
3%
3%
Dale Kittendorf
Mixed
Some trouble with connectivity. Bluetooth not super strong. Works consistently with cable but I wanted it for remote functionality… nice dial feel and go0d when it connects
Hendri Kleyn
Fosi Audio20
Positive: Excellent material + build quality and just about heavy enough.
Downside: cannot operate or adjust volume on the top surface. Has to be touched on the side. Sometime a little slippery....
Not impressed by the wobbly volume knob.
Control switches way too small.
Positive: innovative design and acceptable operation.
Great product in general.
Alex
PREMIUM
Very very satisfied with the product. Premium quality, fidgety, works and looks amazing !
Philip
It is a very well built. For such a large device i wish it had better software support functionality to be able to use the wheel for more than just volume.
Ilja
Amazing
Rich textures and layered soundscapes, so small so cute love it
