  • VOL20 *1
  • USER MANUALL *1
Based on 39 reviews
67%
(26)
18%
(7)
10%
3%
3%
Wolfgang Raudszus
Perfect solution
When streaming with iPhone/iPad, you can out the device aside and control volume very simple with Handy knob
Dale Kittendorf
Mixed
Some trouble with connectivity. Bluetooth not super strong. Works consistently with cable but I wanted it for remote functionality… nice dial feel and go0d when it connects
Hendri Kleyn
Fosi Audio20
Positive: Excellent material + build quality and just about heavy enough.
Downside: cannot operate or adjust volume on the top surface. Has to be touched on the side. Sometime a little slippery....
Not impressed by the wobbly volume knob.
Control switches way too small.
Positive: innovative design and acceptable operation.
Great product in general.
Alex
PREMIUM
Very very satisfied with the product. Premium quality, fidgety, works and looks amazing !
Philip
It is a very well built. For such a large device i wish it had better software support functionality to be able to use the wheel for more than just volume.
