Product Highlights
Battery Capacity
Lighting Colors
Volume Dial
Bluetooth Connection
Product Highlights
Battery Capacity
Lighting Colors
Volume Dial
Prime Autumn Deal | 20% Off w/ code PAD20
- Connection Method: Bluetooth/USB; Bluetooth Connection Range: ≥10m
- Lighting Modes: Constant Light Mode/Light Off Mode/Auto-Off after 5 Seconds of Inactivity/Spectrum Cycling
- Functions: Volume Up/Down; Previous Track/Next Track; Play/Pause; Mute/Unmute
- VOL20 *1
- 2-in-1 USB-A/C to USB-C Cable *1
- USER MANUALL *1
