  • VOL20 *1
  • USER MANUALL *1
Based on 44 reviews
68%
(30)
16%
(7)
9%
5%
HIROFUMI TOMIDA
The design is good, but...
The design is good,
but it's a shame the volume knob is loose.
Erkki Ylönen
The best volume knob to have.
I love this. I no longer need to have a volume knob on my keyboards - I can control the volume anywhere with the VOL20. The build quality is excellent, and it feels solid and heavy. Very easy to connect to PC. I highly recommend to get one.
Wolfgang H.
Bluetooth Volume Control Knob VOL20
Perfect for volume adjustment, easily control play, pause, previous track, next track. Substantiell weight, providing a stable and slip-free experience during operation. Easy installation. I am very satisfied with the functionality and the quality of workmanship
DocHouse
Better than any control knob
every thing is perfect at this gadget
J.D.
VOL 20
Here's the fidget knob that "feels" a part of audio your phone rocker cannot provide.
