  • VOL20 *1
  • USER MANUALL *1
Based on 40 reviews
68%
(27)
18%
(7)
10%
3%
3%
J.D.
VOL 20
Here's the fidget knob that "feels" a part of audio your phone rocker cannot provide.
Wolfgang Raudszus
Perfect solution
When streaming with iPhone/iPad, you can out the device aside and control volume very simple with Handy knob
Dale Kittendorf
Mixed
Some trouble with connectivity. Bluetooth not super strong. Works consistently with cable but I wanted it for remote functionality… nice dial feel and go0d when it connects
Hendri Kleyn
Fosi Audio20
Positive: Excellent material + build quality and just about heavy enough.
Downside: cannot operate or adjust volume on the top surface. Has to be touched on the side. Sometime a little slippery....
Not impressed by the wobbly volume knob.
Control switches way too small.
Positive: innovative design and acceptable operation.
Great product in general.
Alex
PREMIUM
Very very satisfied with the product. Premium quality, fidgety, works and looks amazing !
