  • Wireless stereo amplifier: Add wireless/network streaming capability to your current speakers, home amplifiers, home stereo, or receiver.
  • Steady flow and high sound quality: Supports playback of lossless music files-MP3, APE, FLAC, WAV with Hi-Res audio. When streaming wirelessly, Bluetooth can reach up to 10 meters. With stream music over the network, Wifi can reach anywhere the signal covers.
  • Multiple Music Sources Protocols: Supports AirPlay, DLNA, TuneIn, iHeartRadio, Deezer, HIMALAYA, Tidal, Napster, Qobuz, and local playback. Also Other audio sources for local music, USB flash drive, NAS, and line inputs.
  • Application: Advanced circuit design with built-in speaker protection circuitry, best suited for your home bookshelf/ceiling/desktop/speakers; recommended for home TV audio, computer audio system games, tower speakers, and garden speakers. If you have high knowledge in the audio field, the small and compact design is also suitable for car audio systems. You can enjoy high-quality music everywhere!
  • Multiroom Control: Enables multiroom and multizone streaming through multiple devices connected to the same network and control with your phone.
Fosi Audio T10 WiFi & Bluetooth 5.0  Amplifier 2 Channel Stereo Amp Receiver Class D Amplifier, Home Amplifier for Speakers with spotify,airplay,Multiroom/multizone Digital Audio Speaker AmpFosi Audio T10 WiFi & Bluetooth 5.0  Amplifier 2 Channel Stereo Amp Receiver Class D Amplifier, Home Amplifier for Speakers with spotify,airplay,Multiroom/multizone Digital Audio Speaker Amp
Model T10
Output Power 100W +100W@3Ω
Terminating Impedance 2Ω-8Ω
Input Mode Wi-Fi + Bluetooth + U-Disk + AUX
Output Mode Passive Speakers + PRE-OUT
Frequency Range 20Hz-20kHz(±1dB)
THD ≤ 0.01%
SNR ≥ 115dB
Bluetooth Transmission Distance 32ft/10M
Bluetooth Name Fosi Audio T10
Wi-Fi Name Fosi Audio T10
Device Dimension 148mm (length) x 115mm (width) x 29mm (height)
Power Supply 24V 4.5A
Fosi Audio T10 x 1
Remote Control x 1
Antenna x 2
24V Power Supply x 1
Video
