  • 100W X 2(4 ohms, 20 Hz - 20 kHz, 0.04% THD), comes with a 24V power supply. If your usage scenario is smaller, it can also drive larger speakers, such as those rated at 280 watts (8 ohms) and 320 watts (4 ohms). Please note that this is applicable only for passive speakers.
  • Advanced circuitry design, built-in speakers protection circuit, best for bookshelf/computer/desktop/speakers in your home
  • Small simple compact design but practical and powerful, Hi-Fi Bluetooth amplifier exclusively designed for the customers who pursue HiFi sound;
  • Bluetooth 5.0 core, up to 33ft connection range guarantees low signal delay. No pop, no audible noise when Bluetooth connection is established;
Fosi Audio BT20A Bluetooth 5.0 Amplifier
Fosi Audio BT20A Bluetooth 5.0 Amplifier 2 CH
Power supply range 12v-24v
THD ≤ 0.5%
SNR ≥ 98dB
Input sensitivity ≤ 280mV
Bluetooth transmission distance 28ft
Terminating impedance 2Ohm - 8Ohm
Output power 100W + 100W
Input mode Bluetooth and Analog
Bluetooth Name Fosi Audio
Bluetooth chip ATS2853
Power supply 24V 4.5A
Amplifier 1
Power supply 1
AC power cord 1
User’s Manual 1
