Optimized For Your Battleground
More game-specific optimizations are coming soon to the Fosi StepSense C1 Gaming DAC as StepSense™ continues to evolve—giving you sharper footstep cues across even more titles.
Dynamic Blast Suppression
Built for Fatigue-Free Gaming.
Continuously monitors audio levels and applies real-time dynamic attenuation above set thresholds to soften sudden gunfire and explosions.
AI Voice Noise Cancellation
Crystal-Clear Team Comms
Actively suppresses keyboard clicks, fan hum, and ambient room noise in real time so every callout comes through clean
Web APP Control
Tune Without Bloat.
Control and fine-tune all your gaming audio settings directly in your browser
Fine-tune your Fosi gaming DAC settings in the browser. Press Mic Mute and FPS simultaneously to open the C1 Web App
Make Sound Your Own
Choose from StepSense™ modes, built-in presets, and community profiles to match your gear—let our Smart Assistant craft your custom PEQ, or fine-tune every frequency yourself.
Dedicated 3.5mm Connections
Total Gear Freedom
Supports both 4-pole (TRRS) gaming headsets with built-in mics and standard 3-pole (TRS) stereo headphones—no splitters or adapters required
The Fosi StepSense™ C1 3.5mm Jack, designed for separate headset, headphone, and microphone connections, offers greater flexibility.
Plug in.Play Anywhere.
No Driver Required.
Plug in the Fosi StepSense™ C1 and play—no drivers required. Switch to PS5 or Nintendo Switch mode with a single button press.
Snap Into Place
Enjoy a quick, hassle-free setup with C1's magnetic design
Everything In The Right Place
C1 Makes Your Headphones Game-Ready
Specification
ChipsetXMOS Processor
InputUSB-C, 3.5mm Microphone
Output3.5mm Headphone
Maximum Sampling RatePCM 32bit/48kHz
Rated Power Output 120mWx2 @32Ω
Noise Floor≤4μv (A-weighting)
StepSense™√
Clipping Suppression√
AI Noise Reduction√
Weight 136g
Independent Mic Control √
Dimensions4.15 × 4.15 × 1.2 cm
What's in the Box?
Everything you need to get started with your Fosi StepSense C1, including the DAC, a USB-A to USB-C cable, a protective PE bag, and a user manual.
What Is the Fosi StepSense™ C1 Gaming DAC and Headphone Amp?
The Fosi C1 is a gaming DAC and headphone amplifier designed to enhance your gaming audio experience. Featuring StepSense™ footstep enhancement, adjustable dynamic blast suppression, and AI-powered microphone noise reduction, it helps FPS players focus on important in-game audio cues while enjoying clearer team communication.
