Capable of up to PCM 32bit/768kHz lossless audio, it delivers wired-grade sound quality with the convenience of wireless control.
Chipset
Network
Bluetooth
Remote Control
Power
DC 12V 1.5A
Input Sampling Rate
OPT: PCM 24bit / 192kHz
BT: PCM 24bit / 48kHz
Airplay 2: PCM 16bit / 48kHz
HDMI: PCM 24bit / 192kHz
Wi-Fi: PCM 24bit / 192kHz
Streaming Protocols
APP
Dimensions
  • Fosi Audio S3
  • Bluetooth Remote Control
  • Quick Guide
  • DC Power Adapter
  • Optical Cable
How to download S3 firmware?
  • 5 stars: 41 (69%)
  • 4 stars: 13 (22%)
  • 3 stars: 4 (7%)
  • 1 star: 1 (2%)
Michael (United States)
A very competant streamer
Frank (United States)
I bought this to update the inputs of my classic Sansui G6000 receiver. I’m going from a 7.1 a/v receiver to a 2.1 channel set up. Wow! The new school AKM DAC coupled with my old school A/B class receiver sounds amazing! Detailed and full, warmth with punch. I can retain my sub and just connect my tv with the eARC HDMI connection and my digital sources remain in the same. Easy switching through the tv for gaming, Apple TV and movies. Once the streaming services that I use, Pandora and Amazon Music come on line, I’ll give this 6 stars. Streaming through AirPlay is not great if you walk out the room with your phone… the connection becomes unstable quickly. Other than that, this punches above its weight. Can’t wait for the next update!
Samir (Azerbaijan)
Super quality
Peter (Hungary)
Jay (United States)
Love it so far
Fred (Australia)
After purchasing the S3 + ZA3 bundle I could not be happier with the quality of equipment and such an easy setup to match my speakers. After unpacking I realised I was missing a speaker cable and with a quick response from Fosi customer service via email, they posted the additional cable which arrived promptly! I could not fault this. Well done Fosi for looking after customers that matter to you…Oh and big thanks to Sherry! 🙏🏼
Vincent (Germany)
Super Streamer
ch habe den Fosi Audio S3 als moderne Streaming-Brücke für mein Setup aus Audionet MAP 1 und AMP 3 gekauft. Da ich die hochwertigen Wandler des MAP 1 nutzen wollte, habe ich den S3 per Toslink verbunden und das Ergebnis ist fantastisch. Der Sound bleibt extrem klar und dynamisch, genau so, wie ich es von meiner Kette gewohnt bin.
Besonders beeindruckt hat mich die Unkompliziertheit: Während Hi-Res-Streaming (z. B. Apple Music) früher über USB oft mühsam war, klappt es hier jetzt in Sekunden. Der S3 ist zwar winzig, bietet aber eine saubere Performance ohne Kompromisse. Auch die eigenen Wandler des S3 klingen für diese Preisklasse überraschend detailliert in den Höhen und im Bass. Eine perfekte Lösung, um hochwertige Klassiker fit für das digitale Zeitalter zu machen!
Rough start, but has promise….
Opón getting the streamer I was very disappointed that Tidal connect did not work out of the box :( this was such a bad first experience with the brand, so I contacted support and got that started to try and see if they could help.
Well…. A few days later, Tidal updated the app and sure enough, things started to work. Fosi did apologize, even though I do think it was more a Tidal issue than a Fosi, but what do I know.
Regardless, they kept communicating and I’m now a customer for life. It’s funny but it’s when things go wrong that you see what a company is really like.
The streamer works great and I’m happy, and they have also promised to add more feature and make it better, and this will make this purchase worth even more.
Stretoo (France)
Le Fosi Audio S3 est une réussite sur le plan du rendu sonore grâce à une technologie de qualité bien maitrisée. L’intégration initiale au réseau Wi-Fi est aisée, la fonction Bluetooth est efficace, à noter qu’elle doit être activée lors de cette procédure pour un smartphone sous Android (ceci n’est pas mentionné au point 1 de la procédure du guide d'installation rapide actuel). La partie logicielle n’est pas encore à maturité, Fosi Audio confirme que certaines fonctions essentielles sont encore en développement, elles seront intégrées dans les prochaines semaines. L’ensemble est perfectible principalement en ce qui concerne la gestion des entrées/sorties qui n'est pas très intuitive autant sur le streamer que sur la télécommande. Les 4 indicateurs lumineux sur le boitier sont peu lisibles en plein jour si on n'est pas dans l'axe du boitier et qu'on s'éloigne un peu de lui (en utilisation de salon par exemple). Ils mériteraient d'être plus lumineux et plus gros ou, encore mieux, que le boitier dispose d'un écran attractif. Quant à l’application à télécharger elle est fonctionnelle pour les éléments basiques mais elle est cependant d’une apparence peu réjouissante et toujours en phase d'amélioration.
La partie DAC intégrée est superbe, on peut donc aisément utiliser le S3 comme préampli sans y adjoindre un DAC externe, cela sans sacrifier la qualité du rendu sonore. A mentionner: les deux sorties XLR mais pas de sortie coaxiale (seulement optique). L’entrée RCA est bienvenue pour y brancher un élément analogique.
En conclusion : le S3 est un excellent streamer au rapport qualité prix convaincant. Il restitue un très beau son mais nécessite encore quelques améliorations logicielles et fonctionnelles pour arriver à maturité. Je souhaite vraiment une ergonomie plus efficace et une esthétique plus aboutie à l’avenir afin de hisser le S3 au-dessus de la compétition.
Nathanial
Norris
Billy
Graham (United States)
Spectacular
I use a lot of equipment from these guys (Fosi). All their stuff has been fantastic. This S3 is no different. Just a really nice streamer.
Great streamer worth more than it’s cost
What a great value for a streamer. Worked flawlessly out of the box. Note: this does not have a USB port so you cannot use it as a desktop DAC for your PC. Also most annoyingly it does not have internet radio capabilities so you need yet another 3rd party software to stream internet radio. Again great value and great sound. I cannot hear any difference between Sabre and AKM DACs. Preamp and remote are bonuses that makes the streamer more convenient. Highly recommended but check the features carefully for your application.
Anonymous (New Zealand)
The app
sound is great. I use s3 as my secondary streamer in smaller room and llower quality amplifier (old Yamaha AV receiver). It is comparable to my primary setup consisting WIIM Ultra that I use as streamer only transport to Cambridge Audio DAC Magic and Arcam A15 amplifier. The app needs lot of improvement. Especially with Tidal streaming. Pretty cumbersome. Not easy to move bewteen playpists. Also, you need to hook up ITunes ASAP!
Vladyslav
Amazing for my setup—I plugged in my TV, my JBL 306P monitors, and my JBL subwoofer. Planning to add a Merak CD player, and in the future, a turntable. Perfect for all use cases. Just waiting for the room correction feature!
Tony (United States)
Good streamer, but
I’m very pleased with the streaming performance of the S3. I don’t use the preamp capabilities because it’s not sufficiently versatile and doesn’t have balanced outputs - so I use a separate preamp. Then Fosi released a version without the preamp at a lower price so Inwoukd have saved money if I’d delayed my purchase by a couple of weeks. The remote, with its tiny buttons and markings, is hard to read and use.
Jan (Spain)
Sunil (Canada)
Compact and hard hitting performance
The S3 is quite the surprise. It outclasses the WiiM Pro Plus or WiiM Ultra. But things jump up to a noticable degree with I swapped out the stock switching power supply with a Linear Power Supply, and even further capacitor filter bank. We are talking inexpensive but good products $100cad each to keep it in value proposition territory. Very impressive sound connected to a pair of Genelec G3 monitors. Hats off to the Fosi Team. I won't say giant killer because it's a misleading vague expression. But clearly this is a great inexpensive product. Buy it!
Saul (Mexico)
Excelent streamer.
Is my first streamer and I'm very please with its performance vía Tidal Connect and HDMI Arc conectivity. I just receive its last update of your app and is getting better and better. Please keep up surprise all of us.
On (Hong Kong)
Suggestion about the apps
I use a samsung tab as a remote, but the fosi app only hv vertical view, hope next version will have a horizontal view.
I use s3 as a preamp, so I think the volume in app better have number show the status eg. 1-100 or show in db.
Thanks for your help!
William
Good sounding box, connects quickly and easily. Awesome connectivity on back.
Dave (United States)
Fosi Audio S3, Great!
I’d been looking for an entry level streamer and decided to go for the new S3 since I had a great experience with the little Fosi BT 20A. So far, it’s been great. Sound quality is fantastic and the form factor is good. The app needs work, but is functional for getting the job done.
