- Note: This product is only delivered to the United States. Sorry for the inconvenience caused to you!
High-tech DSP audio processing: the use of high-resolution audio decoding and DSP fine audio processing, software, and hardware perfectly matched to ensure a more stable and clear sound output, enjoy the stereo sound surround sound.
6 exclusive HiFi speaker units + subwoofer: The B10 Sound bar is set up with symmetrical left and right channels, the symmetrical structure counteracts the vibration brought by the sound, ensuring balanced sound output on both sides for a wider sound, and comes with a powerful subwoofer that adds loud and full bass to create an immersive home theater experience for you.
Powerful and extraordinary functions: Professionally meet all your needs, and you can connect your equipment through multiple input options of RCA, optical and Coaxial. It also supports a single cable to connect to the TV. The integrated LED display and Bluetooth connection can reach up to 20 meters, which can be used for long-distance transmission through Bluetooth devices such as smartphones, computers, or iPads. It also supports U-disk connection, just plug in and enjoy the wonderful sound.
Home version of the KTV experience: make the home version of the KTV system simpler, comes with a wireless microphone, adjustable acoustic size, so that your living room in seconds into a professional ktv room, enjoy two people singing in pairs.
High-value and Stylish Appearance: The simple and flexible streamlined shape, sets off the metal mesh decoration, shows the atmosphere and fashion, and perfectly fits your living room, and every detail is not lost. Plus you're covered by an 18-month warranty.
Specifications | Details |
Model | B10 |
Output Power | 120 Watt |
Frequency Range | 80Hz-20KHz |
U-disk capacity | 32GB |
Speaker Specifications | Exclusive HiFi Speaker Unit |
Treble Unit | 2 x Φ50 mm, 4 x Φ52 mm |
Bass Unit | 6.5 inch |
Soundbar Weight | 7.7lb/3.5KG |
Subwoofer Weight | 9.9lb/4.5KG |
Working Voltage | 110-240V |
Power Supply | 20V 3.5A |
