  • SNR≥126dB; THD+N<0.00008%
Swappable Op-Amp Design
Bypass Mode
Trigger In/Out
Perfect Match to ZA3 Amp
  • Maximum Sampling Rate:
    USB: PCM 32bit/768kHz; DSD512
    OPT/COAX: PCM 24bit/192kHz
    Bluetooth: PCM 24bit/48kHz
  • Output Level:
    XLR: 5Vrms RCA: 2.5Vrms
  • Output Mode: XLR, RCA
  • SINAD: 126dB
  • THD: ≥120dB
  • THD+N: <0.00008%
  • Dynamic Range: ≥123dB
  • Noise Floor: ≤2μV
  • Bluetooth Version: 5.0
  • Power Supply: DC 12V 1.5A
  • DAC ZD3 *1
  • 12V Power Adapter *1
  • Infrared Remote Control *1
  • USB-A to USB-B Cable *1
  • 3.5mm Trigger Cable *1
  • USER MANUAL *1
From $179.99
DAC Preamp
XLR, RCA
<0.00008%
≥126dB
Chipset
DC 12V/1.5A
From $119.99
DAC+Headphone Amp
250mw@32Ω
RCA, 3.5mm Headphone Jack
>103dB
Chipset
16-300Ω
DC 12V/1.5A
From $199.99
DAC+Headphone Amp
2x 2.1W@32Ω
≤ 0.0002%
≥121dB
Chipset
16-300Ω
DC 12V/2A
From $99.99
DAC+Headphone Amp
1.1W@32Ω
USB-C, Optical
≤0.001%
≥120dB
Chipset
16-300Ω
How to replace the op-amps?
  • 5 stars: 197 (82%)
  • 4 stars: 30 (13%)
  • 3 stars: 7 (3%)
  • 2 stars: 2 (1%)
  • 1 star: 4 (2%)
David` (United States)
DAC/AMP/Speakers for under $1000. Sounds great!
Ordered a ZD3, ZA3, and SP601 speakers. Sounded very good. The speakers have an opening on the back and bounce bass sounds off the wall behind them. I happened to have a powered subwoofer that had a faulty amp. So, I removed the giant, heavy amp and bought a Fosi Sub-woofer amp for cheap! Hooked it up and now have the sub-woofer integrated in the setup. As a 65 yr-old audiophile from way back thru all the power amps of the 70s and 80s, this thing really produces wonderful sound. Using Apple Music high-fidelity streaming audio in Bluetooth mode on the ZD3, it is very clean sound. As an experiment, I hooked my turntable and CD player to the input on the ZA3 using the RCA jacks, and it works wonderfully also. Overall, very impressed with what Fosi has done with these components!
Yankele (Ecuador)
Excellent DAC
I got this DAC to add digital inputs to my vintage HIFI system. Saw couple reviews and I liked it a lot. It's small but hefty, well constructed and most importantly sounds awesome! My onkyo A 9555 now sounds amazing when playing CDs!.
John (New Zealand)
A noticible upgrade to a cheap DAC
The Fosi Audio ZD3 is a noticeable step up in sound quality, delivering a cleaner and significantly more dynamic sound than my old DAC. It does a brilliant job as the dedicated DAC for my Merak CD player. Running it balanced into the matching Fosi ZA3 amp integrates the two units perfectly, resulting in a lively and engaging listen.
Andrés (Chile)
A fantastic DAC with balanced outputs and premium sound
The ZD3 has been a perfect match for my ZA3 amplifier. Setup was quick, and everything worked immediately through the balanced XLR outputs.
The sound is clean, transparent, and highly detailed without becoming harsh. The DAC provides excellent instrument separation, a wide soundstage, and impressive dynamics. Bluetooth performance is also surprisingly good for casual listening.
I also appreciate the solid aluminum construction, responsive remote control, and intuitive interface. It feels like a premium product at a very reasonable price.
If you're looking for a balanced DAC to pair with the ZA3 or any quality amplifier, the ZD3 is an excellent choice.
p
phdejo (Slovakia)
Hitesh (India)
Great Full Sound Stage Music
I had never heard a sound like this before hearing this—and installing the Sparkos SS3602 in it has truly been the icing on the cake.
Kent (Norway)
ZD3 an absolutely fantastic product.
I absolutely love the ZD3 and the service from Fosi. Just ordered the BOX X5 as well now.
Jason (United States)
Good purchase
Works great as a dac/preamp for my Dayton audio hta200. The ZD3 gives me remote volume control for the Dayton. Anyone who owns the hta200 knows that the supplied remote is useless! I perceive the ZD3 as improving the sound as well!
Peregrine (United States)
So far so good
I’m still early in the process of returning to Hi-Fi. My ZD3 arrived nicely packaged and in perfect condition. Instructions were very clear and I had no trouble connecting it to my Fosi preamplifier and amplifier. So far I’ve been using it to connect via Bluetooth to Spotify on my iPhone with great success. I bought a cheap iPhone 13 camera adapter and attempted to connect to the DAC via USB, but failed. Either this is due to a faulty adapter or fundamentally not possible. I’ll sort it out. Meanwhile I’m going to try connecting a CD player via fiber optic as an alternative to Bluetooth. I’m also on the hunt for a vintage turntable. I’m enjoying this project immensely.
Perry (United States)
Fosi Audio ZD3
I ordered me a new ZD3 DAC and can't wait to give it a test drive. I read ALL the reviews and it was rated "Top Shelf" and after reading all the info and tech data, it was an easy choice PLUS, they gave me a nice little discount for being such a nice guy (not really). I should have it in hand in a couple days along with 1TB drive with ALL DSD music files my bro hooked me up with. I'll give another review once I get it up and running. No need for the tiny amps though as I run 2 Phase Linear 2 channel amps pushing 500WPC and 350 WPC, a custom built Carver Pre. I build all my own equipment but a DAC is out of my wheelhouse. Can't wait. Very cool looking too
Sanjay (India)
Melodious. Superb. Economical.
ZD3 + ZA3 = Excellent. For bit perfect audio my configuration is like this. Mac Mini M4 USB out to ZD3. ZD3 XLR out to ZA3 XLR In. Subwoofer connected to ZAR sub out. Controlling audio through ZD3. Sparation perfect, Vocals Perfect. I love stereo sound. Vocals comes from centre, one can identify all instruments playing in the song. Better than my Marantz 5004 AV Receiver combination.
Ian (Canada)
Extremely pleased
This is my first hi-fi system after 20 years soundbars and one box items.
I chose the ZD3 after seeing multiple positive reviews and matched it with ZA3 amps.
It integrated seamlessly and I'm delighted.
GB (Hungary)
good price/value rate
Petter (Norway)
Super quality and sound
I got this recently and tried it and the quality and sound is great. Would recommend
Tony (Canada)
ZD3 DAC
Perfect match with ZA3
cons: remote is looking ugly.
Moisés (Spain)
Auriculares
Se puede conectar por Bluetooth a los auriculares el fosi zd3 o tengo que comprarme también el fosi zh3 que tiene salida de auriculares.. otra pregunta no interfiere el altavoz de la TV, yo con fosi auriculares y mi mujer con el audio de la tele viendo una peli.. esque soy un pelin sordo y para no subir mucho la tele..
David (United States)
Amazing dac, better price.
This is an absolute steal for less than two hundred.
Balanced outputs, 12v trigger, remote, hdmi arc, good dac chip, easy to read volume display.
Do yourself a favor and get it. I use it to feed my za3 xlr input and love it!
Del (United Kingdom)
ZD3
Running it on usb the pc and hdmi to my monitor for when I'm not using the pc zd3 paired with za3 powering a pair of eltax monitor III not the active monitors the passive monitors and Cambridge audio s90 sub with a few upgrades to the sub
Pete (Greece)
Zd3 review
The dac is perfect. Clean audio without any noise. It is connected via usb to my pc and then RCA to fosi GR70 and balanced to ZA3. Both sound great the pre amplification stage is very natural and I cannot detect any colouring to the sound. I have also tried the Bluetooth and only noticed a slight reduction in volume but it is expected. I recommend this dac as it provides a complete solution for desktop audio.
George (Qatar)
Wow superb product
Greetings from Qatar
Amazing product
