  • Input Mode: MM+MC RCA
  • Output Mode: RCA
  • THD: ≤0.009%
  • SNR: ≥ 92dB
  • Power Supply: 16V/1A
  • BОX X5 Phono Preamp x 1
  • 16V 1A Power Adapter x 1
From $39.99
Active Speakers + Headphone
Bass & Treble Control
≥ 70dB
≤ 0.08%
12V/1.5A
From $69.99
RCA+3.5mm
Active Speakers
≥ 98dB
≤ 0.1%
12V/1.5A
Fosi Audio Box X3 Bluetooth Vacuum Tube Phono Preamp - Fosi Audio
From $59.99
Bluetooth + AUx+ RCA
Active speakers
≥ 70dB
≤ 0.1%
12V/1.5A
From $89.99
RCA+3.5mm AUNo
RCA+3.5mm AUNo
≥70dB
≤ 0.1%
12V/1.5A
  • 5 stars: 96 (89%)
  • 4 stars: 8 (7%)
  • 3 stars: 1 (1%)
  • 2 stars: 1 (1%)
  • 1 star: 2 (2%)
It works very well!
Meu (Brazil)
Excelente
O Fosi Box X5 melhorou muito o som do meu toca-discos (eu estava usando o pré de phono embutido)!
Infelizmente não consegui me livrar do "humming", aquele ruído de fundo, mas mesmo assim valeu a pena, é um excelente custo-benefício.
O review completo do Box X5 está disponível no canal Meu Áudio.
Peregrine (United States)
Satisfaction with my Box X5
I purchased the Box X5 phono pre-amp together with the LUNA3 turntable. The Box X5 arrived promptly while I had to wait a couple of weeks for the LUNA3. Once the turntable arrived I unboxed everything. All the components arrived in excellent condition. Installation of the Box X5 and turntable was simple. My only comment is that the ground post is not where I would have expected it, but I’m sure Fosi has their reasons. The RCA cord supplied with the turntable included the grounding wire and there was sufficient length for it to easily bridge the distance to the terminal.
Peter (Hungary)
Great quality phono preamp
GibH (United States)
Big sound in a small package
This is a great phono stage for its price. If youre looking for just great sound to actively listen to music on your turntable through good speakers, this is it. If you deem yourself an audiophile (you know, the pretentious type), this product still hits way above its weight and produces great sound for you too. Please dont be fooled, this is really all one needs to achieve very, very, good sound from their music (given they have a decent setup). But if you’re searching for exceptional, heavenly, sonic accuracy (which is a farce), a wide soundstage, airiness, and bragging rights, then throw a couple thousand dollars at another phono stage so you can test ad nauseum the quality of your equipment rather than enjoy good music. Fosi X5, Great product.
Daz (United States)
Fosi Audio Box X5
Partnered this with a Rega Planar 3 RS and an Arcam A5+, I was floored by what I was hearing! Listening to Tears in Heaven from Eric Clapton Unplugged, I had to listen to it a second time. I was hearing things I’d never heard before and had the sensation they were in the room with me. I can definitely recommend one.
Zlatri (Sweden)
Phono Preamp
Karl (France)
What else?
Petter
Works well
Paulie (United States)
Great Phono Preamp
My Audio Technica TT has a built in phono preamp which gets the job done. However, the audio tends to sound low and diminished at times depending on the music style. I bought the X5 to bump the gain just a hair to my speaker amp and man it does not disappoint. It gives me exactly the bump my TT needed. Sound quality is fantastic with a beautiful soundstage. The ground attachment is perfect. I don’t have any hum/static/distortion. I would buy the X5 again and highly recommend it. Cheers!
Chuck (United States)
Immaculate!!
Hreinn (Iceland)
Stephan
John
Great product.great value
Mike (United States)
Transformer!
The Box X5 completely transformed the sound of my Audio Technica turntable. Everything felt like it was brought to life. Better lows, mids and highs with a broader sound.
Wilfried (Germany)
I can totally recommend this preamplifier. My Fosi Luna Phono sounds amazing with that preamp.
Fredrik (Sweden)
Don’t use FedEx
The delivery in general took some time and worst of all was FedEx.
FedEx delivery in Sweden is generally considered unreliable and heavily criticized by local consumers. On platforms like FedEx Sweden Trustpilot, the company holds an exceptionally low rating, with hundreds of customers reporting major issues with home deliveries
Jose (Argentina)
Prephono box x5
Bojan (Montenegro)
MM/MC preamp
Awesome prace of tech, minimalistic, the sound is unbealivable ... fast secure shipping. All the best really.
Russell (United States)
Nice product and sounds great to my old ears.
I upgraded from a Box 1 to a Box 5 and glad that I did. Even thought my hearing is not the best, I could still hear the difference. More clarity and definition. Get one if you can't afford those boutique phono preamps.
Jason (United States)
Satisfied!
Sounds good. Honestly can’t tell a difference from preamp of my Dayton HTA200 but sounds great nonetheless. Maybe I need a speaker upgrade next 🤔
Aaron (United States)
Like hearing my records for the first time all over again.
I was new to this vinyl thing and not swimming in cash. I was listening to vinyl but not getting the experience I was told about. So I began a quest to figure out how I could improve my sound without breaking the bank. I knew changing my stylus was something I needed to do. I started with an Ortofon 2M Red then upgraded to the 2M Blue. I noticed an improvement. Next was to choose a pre-amp. But which one in a sea of pre-amps ranging from budget to I'll have to sell a kidney. In my journeys through the interwebs one name was mentioned over and over, Fosi. Then it was hearing of the Box X5. One review after another stating the same thing, "Nothing this good should be this price." What I heard was the most bang for your buck. This is music to my ears. So I took the Fosi plunge. WOW!!! By far the best purchase that made the most drastic difference in my listening experience. To say it was an improvement is the understatement of a lifetime. Weight, clear, depth separation all those words audiophiles go on about I was finally hearing without paying an arm and a leg. I have since become evangelical about Fosi, spreading the good word to all who will listen(and some who'd rather not). Since buying it I come home and listen to at least one record a day because as my heading states it like hearing them for the first time all over again. ALL HAIL FOSI AND ITS BOX X5!!!!!!
GD (Hungary)
Hi Fosi-Audio,
This is also a very nice piece (I bought it together with an MC331). Unfortunately, I haven't been able to use it yet, so I can't give a more thorough opinion, because first I have to renovate my approximately 50-year-old Lenco turntable. With your trust in advance, I hope that this device will give you satisfaction, just like the well-proven MC331.
Sincerely, a customer
Gabor
