- Scientifically Designed - Independent design of the left and right cavity enables this A5 soundbar for TV to boast a wide soundstage and an immersive audio performance. Moreover, the speakers are precisely tilted up 30° in the cabinet to diffuse the sound better around the room.
- Acoustically Tuned - Acoustic engineers with over 20 years of experience professionally tune the two full-range drivers and dual diaphragms to produce loud and clear sound with deep bass. More realistic, more dimension, and more nuanced details than you ever imagined possible.
- Customized Effects - Tailor your listening experience by switching up the equalizer settings from 4 modes (Bass, Music, Movie, or News) with the handy included remote control. Gripping thrillers. Live music. Dramatic series. Immerse yourself in the rich 3D virtual sound.
- Freely Connect - Get this home audio sound bars unboxed and ready in minutes with multiple connectivity options including Bluetooth 5.0 (49ft range), HDMI ARC, Optical, Aux, and USB input. Easy to set up. Easy to use. NOTE: It doesn't work with the Amazon Fire Stick remote.
- Beautifully Crafted - Only 2.8" tall, its exquisite and compact appearance complements your home, whether you place on furniture or mount it (wall mount brackets included). Designed with dust-resistant mesh fabric, this wireless sound bars for TV is easy to clean.
Specifications | Details |
Model | A5 |
Output Power | 60W |
Channel | 2.0 |
Input Mode | HDMI(ARC)/OPTICAL/Bluetooth/3.5MM/USB |
SNR | >75dB |
Bluetooth | 5.0 |
Bluetooth Name | Fosi Audio A5 |
Device Dimension | 470 * 95 * 70MM |
DC Input Range | 15V |
Power Supply | 15V 3A |
Item | Quantity |
Fosi Audio A5 Soundbar | x 1 |
3.5mm to RCA Cable | x 1 |
Wall Mount Brackets | x 2 |
Remote Control | x 1 |
15V 3A Power Supply | x 1 |
User’s Manual | x 1 |
Video
Compare with similar items
