- Enjoyable Stereo Experience - Built-in dual 5W full-range drivers and 2 bass diaphragms, this desktop speakers deliver crisp, delicate, and non-distorted sound. Whether you are watching movies, playing games, or simply listening to music, it will engage you in whatever you are doing.
- Save Valuable Space - Only 2 inches tall, this computer speakers for desktop is slim enough to sit flat below monitors, keeping your desk clutter-free. Moreover, the 45° inclined design helps reduce the blocking interference of objects for a more full-range audio experience.
- Plug and Play - No driver is needed, simply plug in the USB port and audio jacks to use. The volume knob functions as the On/Off power switch and manual volume control dial (when the speakers for PC is On, the LED back-lighting glows).
- Universal Compatibility - This computer speaker works with any device that has a standard 3.5mm headphone jack (most PCs, laptops, tablets, projectors, etc.) Product Dimension: 17.79"x1.96"x1.96" (LxWxH). USB cable and 3.5mm Aux Cable Length: 47.24".
- About Fosi Audio - In the pursuit of finding audio design perfection, we began the iconic audio brand - Fosi Audio. For the past 5 years, we have been designing and developing audio products for real life, aiming to provide the perfect blend of premium acoustic performance with a modern, elegant design. Over 1,000,000 products are sold worldwide.
Specifications | Details |
Model | C1 |
Output Power | 10W |
Bass Diaphragms | 2 |
SNR | 78dB |
Headphone | Yes |
Microphone | Yes |
Channel | 2.0 |
Device Dimension | 17.79"x1.96"x1.96" |
Device Weight | 300g |
DC Input Range | 5V |
Power Supply | USB Powered |
Item | Quantity |
Fosi Audio C1 | x 1 |
User’s Manual | x 1 |
Video
Compare with similar items
