Fosi Audio P1 Vacuum Tube Pre-Amplifier Mini Hi-Fi Stereo Preamp 6K4 *2 Tubes
- Precio habitual
- $49.99 USD
- Precio de venta
- $49.99 USD
- Precio habitual
$49.99 USD - Precio unitario
- / por
🍎NOTE: This is a preamplifier, not a power amplifier or phono preamp, can't be used for turntables or passive speakers.
RCA input to the computer, CD, phone, iPod, and other player and RCA output to the digital amplifiers, active multimedia audio devices for lossless audio(The RCA cables not included).
Small compact design, with optimally integrated circuit to get powerful, dynamic, and sweet sound. Tubes can be replaced by 6J1, 6AK5, EF95, 5654, 403B tubes.
This pre-amp improves everything detail, transparency, immediacy, richness, tone associated with your music.
Built-in Switch impacts protection circuit and overheat protection circuit, the long life span of this unit. All aluminum alloy shells and come with an 18-month manufacturer's warranty.
Type: Player Preamplifier
Model: TUBE-P1
Input: RCA
Output: RCA
Work Voltage: DC 12V
Compare with similar items:
P1 Pro Bluetooth 5.0 Tube PreamplifierP2 Headphone Amplifier Vacuum Tube
I was not satisfied with my power upgrade for my Fosi Audio BT20A Pro, and was looking for some help, well Fosi Audio reached out to me with the Fosi Audio P1 Vacuum Tube Preamplifier. The sound difference was Fantastic, and I’m sure anyone would be happy with this Preamp upgrade.
I am using a wireless mic receiver that connects to an RCA to HDMI converter. The output of the converter goes to an LG Soundbar (the amplifier). In this configuration, the signal from the receiver to the HDMI converter was too weak. I installed the preamp to boost the signal and it worked well.
I did however drop the P1 with tubes and shattered both tubes. I had to purchase replacement tubes and things worked out well since the replacement tubes were 17mm shorter than the tubes that came with the P1. This was great for me because I am mounting behind a TV with limited space. I made a custom mounting bracket with a tube protector (against hitting the stone wall if someone swings the TV in that direction).
Overall I am very happy with the P1 and would recommend.
Thank you
Great find. It gave a good boost to my BL20C to improve clarity and low frequency depth to my office music set up paired with Mission M70. Music source from FLAC files, Spotify and Tidal through my laptop... No regrets and happy here 😊
I heard good comments about the P1 and decided to try it. This preamplifier has (2) 6K4 tubes. And 5532 opamps. Like that the P1 brought “life” to the music. The bass heavier. Voices are clear and powerful. Highs are crisper. With Class D sounded pretty good, but with class A/B. Wow, Clean, details, layering, heavy bass, really really good. Of course, sounded good but with limitations. The sound stage isn’t wider. Its at the center. I did several test changings the opamps, yes you can change the opamps. And that gives some change in the sound. The tubes its other thing i tried. I changed the 6K4 with the 5654 GE. The sound with these tubes is warmer and some holographic. I forgot to mention, the electronic components are good quality brands. In addition, i like the clicking feeling raising the volume. Comparing it vs P3. The P3 its good looking and more versatile because has bluetooth and headphone amp. But The P1 maintains the Fosi tradition of fun audio devices.
I had a good experience with others Fosi products like the P2,P3 & V3. I heard good comments about the P1 and decided to try it. The P1 is a hybrid preamplifier. Hybrid because its a solid state with Vacuum tubes. The preamplifier has (2) 6K4 tubes. And 5532 opamps. Like that the P1 sounded powerful and loud. I connected it to the V3. The P1 brought “life” to the music. The bass heavier. Voices are clear and powerful. Highs are crisper. I did the same setup but using my main audio equipment power amplifier. Wow!, the combination was awesome. Clean, details, layering, heavy bass, really really good comparing that vs the original $1k pre. Of course, sounded good but with limitations. The sound stage isn’t wider. Its at the center. I did several test changings the opamps, yes you can change the opamps. And that gives some change in the sound. The tubes its other thing i tried. I changed the 6K4 with the 5654 GE. The sound with these tubes is warmer and some holographic. Ill try with other tubes. I forgot to mention, the electronic components are good quality brands. In addition, i like the clicking feeling raising the volume. The only thing i don’t like is the power supply, maybe with a better PS the soundstage will increase. Comparing it vs P3. The P3 its good looking and more versatile because has bluetooth and headphone amp. The sound of the P3 its something smoother and match very good with class D amps like the V3. The P3 doesn't have the volume of the P1 but somethimes sounds more sweet. This Fosi Pre amp and the V3 are part of the small form audio equipment line, its other league. Don’t compare with expensive audio equipment, its something good but different market and has limitations. I recommended to match it with class D amps and maybe if you have a power amplifier without a pre, could be an option to try. The P1 maintains the Fosi tradition of fun audio devices.
