DA-2120D Bluetooth Audio Amplifiers 2.1 Channel Stereo 100W Power Amp
100W Power Amp USB Coaxial Optical AUX Remote Control For Home Speaker
2.1 Channel Stereo amplifier
Bluetooth 5.0 Audio Amplifiers
2.1 Channel Audio Amplifiers
Fosi Audio DA2120D Bluetooth Audio Amplifiers 2.1 Channel Stereo 100W Power Amp USB Coaxial Optical AUX Remote Control
Prix habituel
$159.99 USD
Prix soldé
$159.99 USD
Prix habituel
$159.99 USD
Model DA2120D
Output Power 100W + 100W @4Ω
Terminating Impedance 4-8Ω
Input Mode Bluetooth + 3.5mm AUX + PC-USB + Optical + Coaxial
Output Mode Passive speakers + Active speaker + Active subwoofer + Headphone output
Frequency Range 15Hz - 20kHz
PC-USB Input Sampling Frequency 24Bit/192kHz
Optical/Coaxial Input Sampling Frequency 24Bit/192kHz
THD ≤ 0.001%
SNR ≥ 90dB
System Supported XP/W7/W8/W10/MAC/Linux
Bluetooth 5.0
Bluetooth Name Fosi Audio DA2120D
Bluetooth Transmission Distance Up to 50ft
Remote Control Distance Up to 20ft
Device Dimension 4.72*5.31*1.37inch
Working Voltage 12V - 24V
Power Supply 24V 4.5A
DA2120D Amplifier x 1
DC 24V Power Supply x 1
Remote Control x 1
Bluetooth Antenna x 1
Optical Cable x 1
PC-USB Cable x 1
3.5mm to RCA Cable x 1
Download DA2120D User Manual
Compare with Similar Items:
DA2120C+32V Bluetooth Amplifier 2.1CH 120W x2
Based on 1 review
100%
Justin Essagian
Good, but falls a little short
Does exactly what I need it to do, no quality issues. Only downsides are that the headphone output in the front doesn't automatically mute the speakers and the inside passive speaker holes are oriented in very awkward directions for use without banana plugs.
