A ultra mini Bluetooth 5.0 audio amplifier for passive speakers that features stereo 100 watt x2 power to provide you with high-fidelity streaming music.
Features with 6 kinds of input modes: A mini DAC Bluetooth amp that features Bluetooth, USB, coaxial, optical, 3.5mm aux, and USB flash disk inputs, which gives you more options when listening to high-quality music.
With Bass and Treble Control: as soon as you use the remote control to control the bass and treble sound as you like, you can get different excellent HiFi sounds.
Up to 50ft: Bluetooth transmission distance & 20ft remote control distance: Super long Bluetooth transmission distance and remote control distance ensures you connect and control audio devices from a distance at home.
Specifications | Details |
Model | DA2120B |
Output Power | 100W + 100W @4Ω |
Terminating Impedance | 2-8Ω (Recommended 4ohm) |
Input Mode | Bluetooth + USB + Coaxial+ Optical + 3.5mm AUX + USB Flash Disk |
Output Mode | Passive Speakers |
Frequency Range | 15Hz - 20kHz |
USB Input Sampling Frequency | 16Bit/48kHz |
Optical/Coaxial Input Sampling Frequency | 32Bit/192kHz |
THD | ≤ 0.001% |
SNR | ≥ 92dB |
Input Sensitivity | ≤ 280mV |
USB Flash Drive Storage | 32GB |
USB System Supported | XP/W7/W8/W10/MAC/Linux |
Bluetooth Transmission Distance | Up to 50ft |
Remote Control Distance | Up to 20ft |
Device Dimension | 5.5*4.3*1.3inch |
Power Supply | 24V 4.5A |
Item | Quantity |
DA2120B Amplifier | x 1 |
24V 4.5A Power Supply | x 1 |
Remote Control | x 1 |
RCA Cable | x 1 |
PC-USB Cable | x 1 |
Optical Cable | x 1 |
User’s Manual | x 1 |
