Limited-Time Flash Sale: Save 30% | Code: WFS30
Specifications | Details |
Power supply range | 12v-24v |
THD | ≤ 0.5% |
Frequency Range | 20Hz - 20kHz (±1 dB) |
SNR | ≥ 98dB |
Input sensitivity | ≤ 280mV |
Bluetooth transmission distance | 28ft |
Terminating impedance | 2Ohm - 8Ohm |
Output power | 100W + 100W |
Input mode | Bluetooth and Analog |
Bluetooth Name | Fosi Audio |
Bluetooth chip | ATS2853 |
Power supply | 24V 4.5A |
Item | Quantity |
Amplifier | 1 |
Power supply | 1 |
AC power cord | 1 |
User’s Manual | 1 |
