  • 100W X 2(4 ohms, 20 Hz - 20 kHz, 0.04% THD), comes with a 24V power supply. If your usage scenario is smaller, it can also drive larger speakers, such as those rated at 280 watts (8 ohms) and 320 watts (4 ohms). Please note that this is applicable only for passive speakers.
  • Advanced circuitry design, built-in speakers protection circuit, best for bookshelf/computer/desktop/speakers in your home
  • Small simple compact design but practical and powerful, Hi-Fi Bluetooth amplifier exclusively designed for the customers who pursue HiFi sound;
  • Bluetooth 5.0 core, up to 33ft connection range guarantees low signal delay. No pop, no audible noise when Bluetooth connection is established;
Fosi Audio BT20A Bluetooth 5.0 Amplifier
Fosi Audio BT20A Bluetooth 5.0 Amplifier 2 CH
Power supply range 12v-24v
THD ≤ 0.5%
SNR ≥ 98dB
Input sensitivity ≤ 280mV
Bluetooth transmission distance 28ft
Terminating impedance 2Ohm - 8Ohm
Output power 100W + 100W
Input mode Bluetooth and Analog
Bluetooth Name Fosi Audio
Bluetooth chip ATS2853
Power supply 24V 4.5A
Amplifier 1
Power supply 1
AC power cord 1
User’s Manual 1
  • 5 stars: 47 (87%)
  • 4 stars: 4 (7%)
  • 3 stars: 1 (2%)
  • 1 star: 2 (4%)
J (United States)
Great little amp
Finally got around to setting up this amp. I paired it with a cheap pair of Dual LE43PB outdoor speakers, a little speaker. Used a good speaker wire, 14g. They are 4-6 ohm speakers and I had to turn up the volume a bit to get the sound level I wanted (indoor listening level 50-60 dB) but the sound I got was remarkable spacious and full of depth. Far better than I expected! Super easy setup and Bluetooth connection, I haven't tried the RCA connectors. This is intended for patio use and for that purpose I think it will be great!
GUSTAVO
Best Deal Ever
Great amp. Good sound, low noise.. enough volume. Compact, and well crafted. 100% satisfied
Charles (United States)
Bluetooth receiver
I did extensive research online as to which was the best option to connect my Bose speakers with my Bluetooth and Fossi was the answer. I got it set it up. It sounds fantastic.
Carroll
Compact, very easy to use. Revived my old speakers ! Great sound.
Ciara (United States)
Amazing tiny little amp!
Does everything I need and now we have a sound system! Yay!
Customer (United States)
Great deal!
Wonderful little power amp. Need something small and simple to run some passive speakers? Look no further. Cheap and effective.
Bradley (United States)
Perfect garage amp
Wanted to replace a bunch of old sound stuff that was taking up too much space. This device is perfect. Pair it with my phone and I’ve got music or ball games while working in the garage
David (United States)
Just works
I have a pair of the smaller Advent speakers I purchased in the 1970's and was looking for an amp to drive them that would connect via Bluetooth. The Fosi Audio BT20A fit the bill perfectly. Tiny footprint but with plenty of power to drive the 4 ohm Advents and fill my living room with high quality sound. Simple design and paired easily with my phone. Reasonably priced. Highly recommend if you are in a similar situation.
Paul (United States)
Fosi BT20A
This is a great amp for the price I paid.
Great performance! Crystal clear sound!
Zi (United States)
Works as expected
I bought this to use my outdoor speakers and they sound fantastic. Highly recommend as it makes it really nice to play music from my phone with Bluetooth when on my patio.
William (United States)
BT20A added to low power garage with Echo
I plugged in my FOSI, stereo chord from Echo. Got the treble and base set. Driving Yamaha Outdoor speakers sounds great in my large workshop. Turn on my phone to send music via bluetooth snd it switches automatically!
Philip (United States)
Phil (United States)
Anthony (United States)
Tom (United States)
Very simple to use
These amps are veey simple and robust to use. I have bought over 30 of these amps and installed in my customer homes and VRBO rental property's. They are great because when someone who is connected gets out of range for a given time, it opens itself up for the next user. There is no need to press a button to clear the last user and open it up for the next user. If you were already paired before, it is still in your settings to reconnect again.
Fred (United States)
Love this amplifier
I was able to connect this to my Klipsch KG2s and stream audio with ease. Setup and use are simple and I'm able to use my favorite reference speakers again!
Adam (United States)
Eric (Spain)
Mark (United States)
So happy that I found this amazing little system!
Just wired up my Fosi amplifier on Sunday to two Bose outdoor speakers. Best sounding system I have had so far. The unit came quickly, was easy to connect, easy to pair my phone to and absolutely ROCKS my backyard! GREAT PRODUCT!
Great Surprise in a Tiny Package
A complete surprise. Very powerful for its size. Bluetooth connected immediately. Very Satusfied.
Tony (United States)
Michael (United States)
Sounds so clean and love the ease of use and small form factor.
Jeff (United States)
Great little amp!
Bought one for bedroom bookshelf speakers, not expecting too much for $80. I was amazed by their performance! I've since installed them all over our Yacht Club - Bar/Dining room/Galley/covered deck/Work Dock where any member can enjoy their own music at any time.
Brian (United States)
Perfect for Outdoor Speakers
I have a screened porch and ran speakers both on the porch and out to the yard. I wanted something to play audio from the TV and to be able to play music from my phone. This was exactly what I was looking for. Works great and easy to set up. Small footprint as the power adapter is bigger than the unit itself, but this can be hidden. Bluetooth range is decent, maybe 40-50 feet before it starts to have trouble. The switch is great. TV plays on the speakers if it's on, Bluetooth takes priority automatically. And you can leave them switched on and the Bluetooth doesn't automatically connect, which is a positive feature, because you wouldn't want it connecting all the time anyway.
j
jack (Australia)
amazing little package
beautiful in its simplicity - amazing in its power
Philip
Great value
I’ve been using this as a Bluetooth amp for Yamaha 150 W outdoor speakers on my deck for 3 years with no problems whatsoever. Sound is clear and more than enough power to annoy the neighbors. You can’t beat it for the price.
John (United States)
Wish the build quality was as good as it sounds
This is written pre approaching Fosi for a replacement because the situation shouldn’t exist. Under 2 months old and already the power switch has failed, it’s a flimsy switch but in under 40 operations failed, So going to try to return it. Everything else about the amp in terms of sound, function has been great at the price point but when it comes to adding $10 to maybe use better pots and hardware I would rather have that than to deal with that than being without music for however long this takes
