  • Gold Plated Banana Plugs: An exclusive accessory for Fosi Audio home audio systems, featuring excellent conductivity to reduce signal loss, enabling audio products to seamlessly integrate with your bookshelf speakers
  • Precise Manufacturing Quality: The speaker banana plug is made from aviation-grade aluminum alloy and manufactured through precise CNC machining, ensuring a long service life
  • Easy to Use: Make it easy to install speaker wires, which are very suitable for use with receivers, amplifiers, surround sound systems, banana wall panels, etc.
  • What You Get: Fosi Audio Banana Plugs, 2 Pairs/ 4 pcs
