Knobs designed for subwoofer
Pre-Out Connector
  • Output Power:
  • SINAD: 89dB
  • THD: <0.006%
  • SNR: ≥106dB
  • Dynamic Range: ≥106dB
From $109.99
Bluetooth 2.1 Ch Amp
165W ×2+350W@4Ω
≤ 0.03%
50W x2+100W
Bluetooth + RCA
≤ 0.04%
≥98dB
24V/4.5A
TPA3116 x2
Stereo Mode
XLR Input
Subwoofer Channel
Based on 74 reviews
73%
(54)
16%
(12)
4%
5%
A Sykes
Sounds great, nice subwoofer controls.
I bought this to replace a BT20a pro so that I could power a homemade passive subwoofer. It sounds great and good subwoofer controls. It does run really warm under moderate listening levels. I bought it with the 48v supply to get the most out of the amp. It would be nice if the there was an option for the sub frequency setting to actually filter out the lower frequency from the main speakers.
David James
Perfect little amp solution.
Great lille digital amp, have it setup in my workshop/study. Upgraded from the standard version for supporting bigger standmounts and a sub, not disappointed. Easy connection & good sound quality
Brent Johnson
Daryl O toole
Runs a little hot
Happy enough with the unit. I added an old cpu heat sink onto to disapate some of the heat.
Im only using two speakers so no sub.
Works well nice setup. But I was surprised at the het of the fosi unit; hence my workaround. Worth getting.
Hadi Zavalaga Badeli
All goods, sound good, good power
But, it is very hot, you have to think a way to make it more cold
