Summer Sale: 20% Off w/ Code SUM20
- High-Performance Amplifier
- 2.1 Channel Amplifier:The BT30D PRO integrated amplifier features two sets of passive speaker outputs and one set of passive subwoofer outputs, making it easy to set up a 2.1 home theater or other stereo HiFi audio systems.
- Exquisite Craftsmanship:This mini amplifier is meticulously crafted with a solid, all - metal body that ensures durability and longevity. The well-designed case, along with the high-quality controls and connectors, exudes a sense of premium build and attention to detail. The exquisite packaging further adds to the overall appeal and value of the bass amp.
- Output Power:
With 32V/5A PSU Stereo; 95Wx2 @4Ω; Mono: 110Wx1 @4Ω - Terminating Impedance: 2-8Ω
- SINAD: 89dB
- THD: <0.006%
- SNR: ≥106dB
- Dynamic Range: ≥106dB
- DC Input Range: 24-48V
