  • Tube MM Phono Preamplifier: This Fosi Audio phono preamplifier removes low-frequency noise and ensures clear sound quality by converting phono signals to line-level signals using high-quality components and low-noise integrated circuits. It is designed to safeguard your turntable thanks to its grounding post
  • 3 Switchable Gain Modes: You can switch between 3 modes: 39, 42, or 45 dB. High compatibility and customizable control are provided by the adjustable gain levels. Also, it has very good circuitry and entry-level, high-end analog sound
  • Tube Preamplifier: With a 3.5mm AUX input, it's also a tube preamp. Fosi Audio used high-quality component parts for the design and assemblage of this phono preamplifier. You can enjoy a very warm and smooth sound
  • Applicable Vacuum Tube Model: The compatible vacuum tube models are 6K4, 6J1, 6J4, GE5654, 6AK5, 66, etc. To make changes to your stereo system yourself, simply swap out the vacuum tubes. Consider that distinct tubes produce various sounds
  • Package Content: You will get 1 x Box X2 phono preamp, 2 x vacuum tubes, 1 x RCA cable, 1 x power adaptor, and 1 x user manual
Model BOX X2
Input Mode RCA+3.5mm AUX
Output Mode Active Speakers
THD ≤ 0.1%
SNR ≥ 98dB
Product Weight 0.66 lb/300g
DC Input Range 12V
Input Voltage Range AC 110V - 240V
Output Voltage Level 600 Mv @3mV 1kHz
Power Supply 12V 1.5A
Box X2 Phono Preamp x 1
Vacuum Tubes x 2
12V 1.5A Power Adapter x 1
RCA Cable x 1
Based on 17 reviews
94%
(16)
6%
Ziggy B
Excellent phono pre amp
Easy to connect, produces warm, fuzzy sound. Looks great next to my audio-technica turntable
Alain Dubi Estrello muñoz
Fosi Box X2
It is an awesome preamp. I'm very happy with it!
r
rolando mora
little giant
It really transform the sound of your vinyl, its warmer with more stage presence.
ED C
So far so good
It's still early... ask me after a month or six months of use. But after a few listens, I'm very happy with the preamp. This was an upgrade from my previous one. Now I need to upgrade the rest of my system.
S.G. Pels
Awesome Sauce!
There are but a few things that are able to put a permanent grin on my face, here’s one of them. So far, every Fosi product I bought exceeded my expectations, this time is no exception. The Fosi tube phono pre amplifier really gives my sl-2000 that extra sweetness that takes me back a “couple” of decades. You guys are like lego’s for big kids!
