Spring Sale | 20% Off w/ code FASP20
Tube MM Phono Preamplifier: This Fosi Audio phono preamplifier removes low-frequency noise and ensures clear sound quality by converting phono signals to line-level signals using high-quality components and low-noise integrated circuits. It is designed to safeguard your turntable thanks to its grounding post
3 Switchable Gain Modes: You can switch between 3 modes: 39, 42, or 45 dB. High compatibility and customizable control are provided by the adjustable gain levels. Also, it has very good circuitry and entry-level, high-end analog sound
Tube Preamplifier: With a 3.5mm AUX input, it's also a tube preamp. Fosi Audio used high-quality component parts for the design and assemblage of this phono preamplifier. You can enjoy a very warm and smooth sound
Applicable Vacuum Tube Model: The compatible vacuum tube models are 6K4, 6J1, 6J4, GE5654, 6AK5, 66, etc. To make changes to your stereo system yourself, simply swap out the vacuum tubes. Consider that distinct tubes produce various sounds
Package Content: You will get 1 x Box X2 phono preamp, 2 x vacuum tubes, 1 x RCA cable, 1 x power adaptor, and 1 x user manual
| Model | BOX X2 |
| Input Mode | RCA+3.5mm AUX |
| Output Mode | Active Speakers |
| THD | ≤ 0.1% |
| SNR | ≥ 98dB |
| Product Weight | 0.66 lb/300g |
| Device Dimension | 4.66 inch/3.85 inch/1.29 inch |
| DC Input Range | 12V |
| Output Voltage Level | 600 Mv @3mV 1kHz |
| Power Supply | 12V 1.5A |
| Box X2 Phono Preamp | x 1 |
| Vacuum Tubes | x 2 |
| RCA Cable | x 1 |
| User’s Manual | x 1 |
Compare with similar items:
