  • Noise suppression: Through the combination of filter capacitors and inductors, the power filter effectively suppresses conducted and radiated interference, reducing the impact of electromagnetic interference on devices.
  • Power purification: Filters out high-frequency noise and harmonics from the power supply, providing a stable and clean power signal, and enhancing the performance of audio and video equipment.
  • Device protection: Reduces the impact of power surges and spikes on devices, extending their lifespan.The
The DC filter not suitable for BOX X5
Based on 21 reviews
90%
(19)
5%
5%
William Smothers
Good customer service
The filters came in exactly as I need them to. I mainly have them if my amplifiers start making noise again. At this point, they don't so these filters are spares to the two I already have. So far so good!
Luis Gabriel Ponte Rodriguez
Works perfecfly and great quality construction
Buying directly to Fosi Audio is hassle-free and quick. Tracking the order is available and the package arrived on time and well packed.
The DC power fIlter functions properly and it sensibly improved my tube amp performance, especially on trebles and soundstage.
I thought it will have a smaller print, but the quality construction is top notch, however it does not occupy much space.
I certainly will buy more Fosi Audio products in the near future.
Thank you
Michael S.
This is excellent.
Periodically, I used to experience a light buzzing sound with my xduoo xd05 pro when using my linear power supply. I don’t have no clue why it emits but when I physically touch it with my finger, it goes away. Well I don’t have time for that. I bought this and no buzz whatsoever. In fact, it sounds clearer and much better. Not sure if it’s placebo but I don’t think so. Buy it!!!!
h
hiwata
Very cost-effective product
I use it with ZA3. I measured what effect this product has. The second photo is without it, the noise is 180mVpp. The first photo is with it, the noise went down to 80mVpp.
In my environment, I was able to reduce noise by more than half. I think this is a very cost-effective product.
Lance Peters
Great Noise Reduction
Used this on a Douk A5 with 32V power supply. There was some low level high pitched noise coming through my speakers with the amp at maximum gain, this filter cleaned it up completely.
I have several Fosi amps and they are all nice and quiet as-is, so Fosi’s supplies must be better.
