  • 2-in-1: Hifi Music Tube Bluetooth 5.0 Home Audio Receiver 2 Channel Amplifier and Headphone Amp. T20X can drive most home passive/desktop speakers and 3.5MM headphones. Achieve Hifi music quality.
  • Bluetooth 5.0: Enjoy superior wireless audio experiences with Bluetooth 5.0 core. Faster transmission and more stable connection extended long range up to 50ft/15m. Wirelessly stream audio anywhere you want.
  • Vacuum Tubes: T20X is equipped with JAN 5654W Vacuum Tubes to get more warm sound. Applicable vacuum tubes model: 6K4/6J1/6A2/6J4/GE5654/6AK5/66*In vacuum tubes, etc. You can replace the vacuum tubes to DIY your stereo system. Different tube with different sound.
  • Product Parameters: MAX Power Output: 100W x2@4Ω, Terminating Impedance: 4-8Ω, THD: ≤0.05%, SNR: ≥ 105dB, Amplifier Chip: TPA3221, Frequency Range: 20Hz-20kHz(±1dB).
  • What you Get: T20X amplifier x1, Bluetooth antenna x1, 5654W Vacuum tubes x2, User Manual x1, 24V/4.5A Power Adapter x1, AC Cord x1, 24-month worry-free warranty, and friendly customer service.
fosi audio T20X bluetooth tube headphone amplifier
fosi audio T20X bluetooth tube heaphone amplifier
Model T20X
Chip Set TPA3221
Output Power 100W x2@4Ω
Terminating Impedance 2Ω-8Ω
Input Mode Bluetooth + RCA
Output Mode Passive Speakers + Headphone
THD ≤ 0.05%
SNR ≥ 105dB
Bluetooth Transmission Distance Up to 28 Ft(10m)
Bluetooth Name Fosi Audio T20X
Device Dimension 5.40 x 4.80 x 1.35 inches
Device Weight 479.8g±10g
DC Input Range 19-30V
Power Supply 24V 4.5A
Fosi Audio T20X Amplifier x 1
Bluetooth Antenna x 1
Vaccum Tubes x 2
24V 4.5A Power Adapter x 1
Compare with similar items
