$109.99
+ Free shipping
Audiophile-Grade Capacitors
Groundbreaking Heat Dissipation
Limited time offer of 15% Off. CODE:FADA15
Model
Quantity
Free shipping
Money-Back Guarantee
Customer support
$109.99
$104.99
Fosi Audio P4 Mini Preamplifer
$99.99
Born for HiFi Enthusiasts
Max Power Output: 300Wx2@4Ω
SINAD: 88dB | SNR: ≥110dB
THD: ≤0.003% | Noise Floor: 140uV ;Frequency Response: 20Hz-20kHz
TI TPA3255 Integrated
Enabling superior audio quality & ultra-low distortion across the audio band with Class-D efficiency
Swappable Op-Amps
Compatible with 8-pin dual op-amps. Roll them to get your preferred sound signature
Audiophile-Grade Capacitorsn
Built-in quality Japanese NCC, ELNA, and German WIMA capacitors for outstanding performance
Japanese SUMIDA Inductors
Professional audio inductors which have lower impedance and enables support for larger currents
Vents on the top and bottom, and whole-body heatsink design enhance air circulation and cooling
Bookshelf Scene
Home Theater
Desktop Scene
Amplifier Comparison Table
BT20A PRO
HT4S
V3
Bluetooth 2.0 CH Amp
Bluetooth 4.1 CH Amp
2.0 CH Amp
300W x 2
30w*4+60W*1
300W x 2
Bluetooth + RCA
BT + 3.5mm AUX + OPT
Passive SPK +Pre-out
Pre-Out+SPK Out
Treble&Bass Control
THD
≤ 0.03%
≥88dB
  • Compact Yet Powerful: The V3 mini power amplifier combines a minimalist design with exceptional performance. With a power output of up to 600W, it can effortlessly drive 2-8Ω speakers, delivering impressive sound quality. Its compact size makes it suitable for various applications, from bookshelves and desktop setups to home theaters.
  • Audiophile-Grade Components: It features the TPA3255 high-end digital class D amp chip and utilizes premium Japanese NCC, ELNA, and German WIMA capacitors, and Japanese Sumida inductors for exceptional audio quality. With a SINAD rating of up to 88dB, an SNR of up to 110dB, and a low noise floor of only 140uV, it delivers exceptional clarity and low distortion.
  • Innovative Cooling: The V3 stands out with its groundbreaking heat dissipation design. Equipped with vents on the casing's top and bottom, and a whole-body heatsink design, it efficiently dissipates heat, preventing damage to components and ensuring optimal performance.
  • Scalable and Fun: Tailor your sound experience by swapping the stock NE5532 op-amps. V3 is compatible with a variety of 8-pin dual op-amps like Sparkos SS3602, MUSES02, OPA2604, OPA2134PA, OP249, AD827, RM4559, LM4562, LME49720HA, etc.
  • Worry-Free: Enjoy peace of mind with the V3 stereo amplifier. It comes with a 24-month warranty, ensuring reliable performance and customer satisfaction. Note: The "Pre-out" level is NOT controlled by the volume control as the V3 is not an integrated amplifier, so the sound is NOT adjustable when you are connected to the "Pre-out". Note: It doesn't come with the orange knob.
  • Chip Set: TI TPA3255
  • Output Power: 300Wx2 @4Ω
  • Input Mode: RCA
  • SINAD: 88dB
  • THD: 0.003%
  • SNR: ≥110dB
  • V3 Power Amplifier x 1
Based on 170 reviews
90%
(153)
5%
(8)
4%
(6)
Guillermo Luis Salinas
Excellent component
Very good team that makes with the p4, recommended
Terry Iverson
Fosi Audio equipment is beyond compare based on price and performance.
Fosi Audio equipment is beyond compare based on price and performance. You can’t go wrong with of anything it so small that the power supplies weigh more and sometimes hard to get them yo stay put with the many cables you can attach. Great equipment!
Anonymous
Excellent value
Bought for desktop use to replace my ancient stereo receiver. Cleaner sound and more power at a 20th of the size and for not very much money at all. Top marks!
Donnie L
V3 Stereo Amp
V3 stereo amp with Vanguard Scouts, wonderful combo, so open and musical!
Anonymous
Great Amp
Used as a replacement for an antique console. Works great.
