The High Quality Operational Amplifier Chip Burson V7, SparkoS Labs SS3602MUSES02 and OPA2134PA can replace the ZA3BT20A PRO, and V3's operational amplifiers and can create different sound quality, providing you with a versatile Hi-Fi listening experience.
SS3602
Based on 107 reviews
82%
(88)
11%
(12)
3%
4%
Robert Scharf
Musical Muses
I’m using V3 Mono blocks with Virtual Hi Fi’s Supersonic V2’s (accuracy, similar to Burson V7V’s but more lifelike/less “flat”) in dominant position and 3 paralleled Muses02’s in secondary position. Soundstage is HUGE, musical, and just enough detail without harshness.
s
steven g.
Hearing is believing
I'm new to the op-amps the new ZH3 gives you the chance to swap out the op-amps and they made it so easy to do..With the sparkos ss3602 you really do need to let it burn in at least 30hrs when i first install it with the hifiman edition xs and sundara the bass was not full , the midrange on some muisc was to forward .. the treble on the XS was sharp it made some vocals sound like they had hint of static or distortation. so after 30hrs of having music play through the ZH3 with the sparkos every thing even out and sounded amazing.. the bass was impactful and solid. the midrange was rich and balance ,, the treble with the edition xs was like it normal was but detaill... with the sundara it it evelated and enhanced them in a great way.. the soundstage on edition xs could be to much and you could be over stimulated on some sources that you are listnen to its not bad just if you are sensitve to that the sundara to dail it in to perfect..with my hearing it made the sundara sound like a headphone that was twice the price . IF you have the sundara and the ZH3 get the sparkos burn them in and enjoy.. Now to wrap up this review this is what i really love the most when it come to eq you really dont have to do much at all on the edition xs i just had to tweek the treable to get rid of the brightness and balace the upper midrange and treable out and for the low end most of the time it was fine but on some music i had to make the tiniest tweek to fill in the bass or make it thumpy .. the sundara depends on the music source . tweek the midrange little to bring it forward .. tweek the bass to make it full and solid or leave it for neutral sound.. the treble is fine.. all in all i highly recommend it.. it will the best upgrade you have made to the ZH3 my friend told me in his ZH3 with the sparkos using the filters on the ZH3 you can mimic smsl , topping and ifi audio with filter and eq.. just buy it and enjoy
LSPowers
Muses02 - trust Fosi for op amps
Bought two Muses02 with my new Fosi ZA3. Nice to be able to trust they are real. Fake ones are everywhere. Added one opa1656 for XLR . ZA3 sounds great. Klipsch rp600 II speakers. Very happy.
Gilles Gingras
fosi v3 with muse02
excelent amp with the muse02 very good sound.
p
peter westermayer
sparkos labs ss3602
the best.
