  • The 48V 5A 10A power adapter supply is specifically designed for use with amplifiers and is ideal for providing reliable power to Fosi Audio amplifiers, such as BT20A Pro, TB10D, ZA3, and V3 amplifiers.
  • Provides a stable and reliable output voltage of 48V for powering your device. Capable of delivering up to 5A/10A of current, making it suitable for high-power applications.
  • Manufactured with high-quality materials, ensuring long-term durability and reliability.
  • Incorporates several safety features, including overcurrent protection and overvoltage protection, to ensure safe operation.
  • The compact and lightweight design allows for easy portability and uses in tight spaces. It can be used in a range of settings, including home, office, or industrial environments.
Customers praised this 48V power supply for delivering substantial power upgrades to amplifiers. Many reported "improved bass and dynamics," "clearer sound," and better performance with speakers. The 10A version significantly enhances audio quality over lower-wattage options. However, some noted transformer hum and questioned value for certain amp models.
  • 5 stars: 31 (91%)
  • 4 stars: 0 (0%)
  • 3 stars: 2 (6%)
  • 1 star: 1 (3%)
Tony (United States)
Excellent value for price
Works great and gives more power than the standard power supply.
David (United States)
Big power, small package!
This power supply is an amazing pairing with the bt20a pro. Peak wattage of 240 a channel in a perfect world. Runs my hard to drive speakers at amazing volumes.
Brick is the size of an old school laptop charger, so make sure you can accommodate.
Havi
Fosi Audio 48V 10A Power Supply Adapter For V3 Mono-
I had planned from the beginning to use the V3 Monos with their own Fosi Audio 48V 10A Power Supply Adapter each. In the meantime I used only one unit to feed the two monos via a splitter cable and a noise filter. I was of course very familiar with the sound after several months. I did not expect to hear a huge change in sound with each unit powered by its own 48V 10A Power Supply Adapter. I was wrong. I was actually shocked by hearing an enormous slam and increased dynamics with everything played, including greater detail retrieval. I then added 4 Sparkos SS3602 Dual Discrete Op Amps but found the improvement in the sound not as significant as using two seperate power supplies. Do I believe investing in a second power supply is worth it? You bet.
Anonymous (Serbia)
Power Supply Adapter ZA3, V3 Mono
Excellent
Ganesh (Australia)
Fosi 48v 10A power supply
Hello All, Just wanted to let everyone know I purchased a second 48v 10A power supply, even though Fosi has said running separate power supply for the V3 monos does not make any difference. Sorry I don’t agree with this statement. With second power supply the BASS control has improved significantly.
Robert (United States)
48v 10a Power Supply Pair for Fosi v3 Mono Amp
Excellent headroom compared to dual 48v 5a. I drive Ohm Walsh 4 speakers that are power hungry and when you turn up the volume it doesn't exhaust the power supply. It's like have a v8 engine instead of a v6 engine. It's overkill but I never run out of headroom as the volume increases.
Nicholas (United Kingdom)
Power Amps
Recently I had to buy another 48V 5 AMP power supply for my twin Z3 MONO amps because the supplied dual purpose 48V 10A power supply was cheaper but simply stupid and impractical.Fortunately I was able to swap out the 48V 10A power supply with my other ZA3 stereo amp's 48V 5A power supply and only buy one more power supply for the Z3's. My other ridiculous purchase was to think that the 0.3 m pair of Fosi speaker cables for my Z3 Mono's would be a sonic improvement, in other words 'shorter is better'. Again impractical and stupid solutions for any audiophile as no difference in quality with my LS50 Meta speakers and great difficulty with speaker placement and setup. I love FOSI products but these silly accessories should cease production as they are misleading hi-fi solutions.
Andrew
Too much power for the bt20a
Too much power for the bt20a pro!
Thomas (United States)
48v power supply
Really enjoying the V3 amp with the 48v power supply, drives my Vienna Acoutics towers with ease, barely gets lukewarm.
Anonymous (Singapore)
48V 10A PSU
Bought them as recommended upgrade to the 48V 5A version for my ZA3 monobloc. To my ears, they open up the sound on my KEF LS50!
j
jo (United States)
Love my Fosi amps
I have five Fosi amps and they are great.
The mono blocks are superb.
John (United Kingdom)
Power supply for amp.
Upgraded from 32 to 48volt 10amp to increase the power of the amplifier. Works well.
Braden (United States)
Quality build
Seems to be great quality build, and pretty much the only power supply that will work for it. Sadly, haven’t been able to use it. I updated my receiver to a newer one that doesn’t have pre-out for front towers, saving it for when I get another set of speakers for garage😂
Magic (United States)
Worth the buy
I bought the Fosi Audio BT30D Pro 2.1 Channel Bluetooth Amp with the 32v5a power supply, which was a decent buy, but the 48v10a power supply boasted the output that really rocks my Micca MB42X G2 bookshelves and Rockville 12" powered Sub, good upgrade.
Meelis (Estonia)
Fosi Audio 48V 5A & 10A Power Supply Unit
Oscar
quick and fast
m
miha (Slovenia)
good PSU
Works.
Michael (United States)
Impressed!
I bought my ZA 3's with the 48v 5A power supply and after doing many upgrades to my system (DAC's, all the OP amps I2S interconnects ect.) I was curious if swiching the power supplies would make a difference. I try to have no expectations so that I perceive actual results and to make sure that my mind isn't playing tricks on me and causing me to spend unnecessarily. I tried to do research is switching from the 48v 5a to the 48v 10a power supply would make much of a difference and I wasn't able to find too much information. In the reviews here it was saying that it improved the bass and dynamics of the music and it seems unlikely that it would but I was shocked to find that it did for me too and I A/B tested the power supplies on songs that I was extremely familiar with and my test concluded that the performance was much better regarding the clarity and micro details. I acutally wanted to send them back to get my $200+ for the 2 power supplies because I didn't think that they would actually make a difference but they did and I think they are a nice improvement to my s;ystem so I will be keeping them! 10/10 would reccomend!
D (Australia)
48v 10A worth it
I think it's the upgrade to 48V 10A, especially if you are running for fronts/stereo for that power
Alan (Brazil)
Excelent product
Excelent product
k
kwangsoo (South Korea)
Where is my thing.Please let me know.
I didn't receive yet what i ordered.
匿名 (Japan)
Fosi Audio 48V 5A 10A Power Supply Adapter for TB10D, BT20A PRO,V3,ZA3,V3 Mono
Jason (United States)
48V 10A PS hum
These power supplies produce a noticeable noisy transformer hum.
John (Canada)
Improves sound and power.
Upgraded the power supply on both my ZA3 mono blocks from 32v to 48v 10amp. More volts = more power as well as clearer sound. Nice upgrade. Next up is upgrading the op amps.
Pétur (Iceland)
Delighted!
It works perfectly as I expected. Many thanks.
ERIC (United States)
Who Knew A Power Supply Could Make A Difference?
I received a pair of FOSI v3 monoblock amps about a month ago with 48v-5a power supplies. They were perfectly good, but for giggles I decided to try a pair of 48v-10a supplies from FOSI to see if they would provide an audible improvement. In short, they did in two ways. The most obvious was in the bass where the output from my Zu DWX bookshelf speakers became deeper, more full-bodied, and tighter. The other improvement was in micro and macro dynamics. A pair of these power supplies are not cheap (especially relative to the price of stock v3 monoblocks), but I believe the improvement in sound quality is worth it. Recommended.
Abdul (United Arab Emirates)
Power Adaptor
Superb Performance. Realy Satisfied.
