  •  Hi-Fi Amp with Clean Sound Quality: Fosi Audio M03 subwoofer amp adopts the Instruments TPA3255D2 chip, High Efficient Power Output Up to 200Watt, providing 150 watts RMS into 4-ohm loads or 120watts to 8-ohm loads. Great amplifier to driver any bookshelf speaker or subwoofer;
  • Subwoofer amplifier and Full-Frequency Mono Amp: Switch to PBTL, it's a Full-Frequency Mono amp for driving passive speakers and powered subwoofer. Switch to SUB, it's a subwoofer amplifier for diving passive and powered subwoofers;
  • Mini Compact but Powerful: Built-in low pass filter for 20-300Hz subwoofers with SUB frequency control, small simple compact design but practical and powerful;
  • Home Hi-Fi amplifier: Exclusively designed for the customers who pursue HiFi sound; MAX Power Output:200Watt. Note: The package comes with a 32V/5A power supply, you need a more powerful power supply to get the MAX power output;
Subwoofer Amplifier 200 Watt Mini Mono Audio Amp Full-Frequency and Sub Bass Switchable Amplifier One Channel Home Theater Single Power Subwoofer Amp Fosi Audio M03
    Model M03
    RMS Power Output: RMS 200watt at 4ohm, RMS 100watt at 8ohm
    Terminating Impedance 4-8Ω
    Input Sensitivity ≤ 0.2mV
    Full Frequency Response Range 20Hz-20KHz(± 3db)
    Bass Frequency Range 20-200Hz
    THD ≤0.03%
    SNR ≥ 106dB
    DC Input Range 24-48V
    Power Supply 32V 5A
    Fosi Audio M03 Amplifier x 1
    32V 5A Power Adaptor x 1
      Compare with similar items
