Specifications | Details |
Model | T10 |
Output Power | 100W +100W@3Ω |
Terminating Impedance | 2Ω-8Ω |
Input Mode | Wi-Fi + Bluetooth + U-Disk + AUX |
Output Mode | Passive Speakers + PRE-OUT |
Frequency Range | 20Hz-20kHz(±1dB) |
THD | ≤ 0.01% |
SNR | ≥ 115dB |
Bluetooth Transmission Distance | 32ft/10M |
Bluetooth Name | Fosi Audio T10 |
Wi-Fi Name | Fosi Audio T10 |
Device Dimension | 148mm (length) x 115mm (width) x 29mm (height) |
Power Supply | 24V 4.5A |
Item | Quantity |
Fosi Audio T10 | x 1 |
Remote Control | x 1 |
Antenna | x 2 |
24V Power Supply | x 1 |
User’s Manual | x 1 |
Video
