  • 24V 4.5A Power Adapter Description:
    AC110V-230V input;
    DC 24V 4.5A output;
    Connector size: 5.5*2.5mm
    Power adapter for class d amplifier;
  • BOX X5 16V 1A Power Adapter Description:
    Input: AC 110V or 230V, 50-60Hz
    Output: AC 16V 1A (Only for BOX X5, do not use with DC-type amplifiers)
    Cable Length: 1.2 meters
    Plug Type: Matches the country of your delivery address
    Important Note: This power adapter supplies AC (alternating current) output, not DC. It is exclusively designed for BOX X5 and should never be used with other amplifiers requiring DC power to avoid damage.
This power supply reliably drives various amplifiers with customers praising its performance and value. Shoppers noted it works well with compatible amps, delivers great sound quality, and offers excellent customer service. However, some units produce audible high-frequency noise or whining sounds. Most customers found it "just as good if not better than $1,000 hifi stereo setups."
  • 5 stars: 15 (88%)
  • 4 stars: 0 (0%)
  • 3 stars: 2 (12%)
EDWARD (United States)
Fosi Audio 16V 1A & 24V 4.5A Power supply
MK
Warm and Full
This is my first pre-amp/hi-fi setup. Cobbled together a few things from Facebook Marketplace and did some service trades, but wanted to pay full price for a new pre-amp and boy. I’ve heard a lot of different big stero/receiver systems at different people’s houses, so this little box going into a little fosi amp left me a bit skeptical but for me right now it’s just as good if not better than $1,000 hifi stereo setups I’ve heard. Very impressed, no complaints.
Ok maybe one. I wish it had a remote or an automatic off switch so the tubes aren’t left on, but I still love it!
MR
All good great price
Michael (United States)
Excellent Inexpensive Gear!!
Took a bit to get the exact power supply made by Fosi but my little amp does not shut down when I push it like it did with a generic power supply.
Alex (United States)
good power supply
Works as advertised
This drives my little Nobsound Q10 amplifier just fine.
r
robin (South Africa)
Power supply
I bought a pre amp from Amazon in America and it was for 110 volt only so I needed to get one for 220 and the fosi website had them. Shipping was painless. Wish I just bought there first. Amazon really should warn people that the voltage won’t work when they see it going to a different region. Usually these power supplies are 110-220 range but not these ones.
Anonymous (France)
Not quiet at all
The shipping was great and it works well. However this power supply make some audible noises (high frequency sound and vibrations on my desk). I can hear it by entering in the living room ...
I did not have these worries from the original one I got with the box X5.
Michele (Italy)
Great!!!
I love your products!!
g
gerard (Spain)
Todo perfecto
Bien empaquetado. buen estado y buena calidad y el enchufe adecuado
Matthew (United States)
Just got it today
Sounds great. Got it hooked up to a fosi bt20a and a pair of jvc cherry wood speakers with ceramic cones and they sound almost as good as my Klipsch speakers.
T.J. (United States)
Fosi Audio 24V 4.5A Power supply for TDA7498E TPA3116 TAS5613 Amplifier
Dmitry (United States)
Audibly noisy
Got it as a replacement for TB10A, and I can hear the power supply. Yeah it's faint, but when it's on your desk you can hear it, and it gets annoying. When it's just plugged into the wall it's a faint fast clicking sound, not too loud, but when you plug it into the amp it's a high frequency whine.
I have two other Fosi power supplies from similar amps and same specs, and they are absolutely silent, you can't hear anything, even when you put them against your ear. I also have another cheap power supply that makes the same whining sound I was going to use originally, but thought that if I got a genuine replacement from the manufacturer it would be good as new, but apparently not.
Mr (United Kingdom)
Fosi Audio Review
I got in touch with Fosi to explain that the power supply for my amp had failed.
``although it took over 20 days to arrive, it’s here now and it works.
Assen (Austria)
Recommended
As described and working great.
Vincent (United States)
Fosi Audio 24V 4.5A 6A 8A Power supply for TDA7498E TPA3116 TAS5613 Amplifier
William (United States)
Best products, prices and customer service!
I ordered a 24v 8a power supply to increase the wattage of my Fosi TP-02 mini amp. The first unit arrived with shipping damage, a cracked case, so I notified Fosi customer service. They immediately shipped out a replacement and it arrived today in perfect condition. Thank you!
