  • Length: 1.2 m (47.24 in)
  • Outer Diameter: 6.5 mm (0.26 in)
  • Connector Type: 3.5 mm to Dual RCA
  • Conductor: 28-strand fine copper with copper foil
  • Shielding: Aluminum foil + copper braided shield
  • Outer Protection: PVC jacket with nylon braid
  • Connector Material: Gold-plated pure copper with anodized aluminum alloy housing
  • Package Includes: 3.5 mm to Dual RCA cable ×1
Customers praised this audio cable for excellent build quality with gold-plated connections and superior sound performance. Reviews highlighted "very musical" playback with "shimmer and tingle" in highs, good frequency response across ranges, and quiet background with no degradation. "Does exactly what it's supposed to."
  • 5 stars: 23 (100%)
  • 4 stars: 0 (0%)
Paul
Unlock the Tone Controls of ZH3
Quality cables. I use them to send analog signal out of the PO on the ZH3 so that I can use the tone controls with an external amp
Paul
Richard
excellent quality as expected
Carlo (Italy)
Benissimo
Markku
 + IM4 + 4.4mm Balanced cable
Rodney (United Kingdom)
Roman (Canada)
Fosi Audio 3.5 mm to CSA adapter cable
The Fosi 3.5 mm to RCA adapter cable is being used to connect a Fosi Merak CD player via its line-out to a Telefunken 6040 all-analog vintage receiver with 40 W rms per channel. The cable build quality is excellent with gold-palter 3.5 mm and RCA connections. The sound was provided using a pair or Wharfedale refurbished Dovedale two-way speakers, circa 1968, with the massive 12" woofers and famous super 3 midrange/tweeter with huge magnet structures. The sound background was quiet. The resulting music playback is very musical with some finesse. The highs shimmer and tingle. Instruments have some separation and "air" around the sound stage. The brass has the desired bite and microdynamics. Miles Davies trumpet sounds like a trumpet, not shrill or squawky. Very enjoyable listen. This combination is not humbled by larger full-scale CD players. This does require mating to high quality electronics and stereo speakers.
Roman (Canada)
Z.A. (Italy)
ottimo
cavo ben fatto ottimo prodotto
Zannini (Italy)
ottimo
Nancy (United States)
Great Cable
The only other 3.5mm to dual RCA cable I have experience with did not sound as good or connect as well. Fosi cable seems to have better frequency high, mid and low. I do like this cable.
Great Cable
Shoyab (India)
Shoyab (India)
Nikolai (Norway)
Good
I used this while testing out some audio products at it was very good without making extra sound unlike the bad quality ones I got before.
Nikolai (Norway)
Good
Feng-Hsiang (Thailand)
good
good
Andrew (Belarus)
A great cable that does exactly what it's supposed to.
Andrew (Belarus)
JC (United States)
Quality Cable
Have been using the cable now for a couple weeks.. the rac ends are solid and grip the posts well. Sound transfer is spot on with no degradation
JC (United States)
Quality Cable
