Knobs designed for subwoofer
Pre-Out Connector
  • 2.1 Channel Amplifier: The BT30D PRO integrated amplifier features two sets of passive speaker outputs and one set of passive subwoofer outputs, making it easy to set up a 2.1 home theater or other stereo HiFi audio systems.
  • Exquisite Craftsmanship: This mini amplifier is meticulously crafted with a solid, all - metal body that ensures durability and longevity. The well-designed case, along with the high-quality controls and connectors, exudes a sense of premium build and attention to detail. The exquisite packaging further adds to the overall appeal and value of the bass amp.
  • If you plan to use a 48V power supply, active cooling (such as a fan) is required to ensure stable operation.
  • THD: ≤ 0.03%
  • SNR: ≥ 108dB
  • Input: Bluetooth + RCA
  • Input Sensitivity: ≤ 600mV
From $109.99
Bluetooth 2.1 Ch Amp
165W ×2+350W@4Ω
≤ 0.03%
Fosi Audio BT30D Bluetooth 2.1 CH Power Amplifier - Fosi Audio
From $89.99
50W x2+100W
Bluetooth + RCA
≤ 0.04%
≥98dB
24V/4.5A
TPA3116 x2
Stereo Mode
XLR Input
Subwoofer Channel
Compact 2.1 Bluetooth amplifier praised for "incredible power" and "crystal clear" sound. Customers said it drives speakers and passive subwoofers effortlessly with excellent bass/treble controls. Common concerns: unit runs hot at higher volumes, some experienced overheating shutdowns. "A little powerhouse" with outstanding value for price.
  • 5 stars: 127 (74%)
  • 4 stars: 26 (15%)
  • 3 stars: 7 (4%)
  • 2 stars: 2 (1%)
  • 1 star: 10 (6%)
Philippe (Canada)
The foundation of a Hi-Fi setup
I was recently inspired to assemble a Hi-Fi setup when my father offered me a vintage turntable. So after a couple of months of searching and info gathering I opted for this expertly crafted mini amplifier.
When I unboxed it, my first impression was that it looked smaller than I imagined. Nonetheless, the BT30D Pro performed beyond my expectations, when I streamed music on a pair of Fluance bookshelf speakers via Bluetooth, i was impressed by the clarity and detail of the mids and highs. Bass and treble knobs are easy to use. Bass is good and I intend to add a subwoofer to the BT30D pro.
I ordered the 48v 5a power supply and the mini amp feels warm to the touch but never hot, I wanted to be sure I had enough headroom for my speakers that have a relatively low sensitivity rating of 85db. I kept the volume knob below 40% and it was loud enough for my taste.
So this is the starting point of my Hi-Fi setup, a compact yet very capable mini amp.
Rob (United States)
This thing jams
I’m very appreciative of the bass/treble adjustments. Works very well with Bluetooth. All switches and knobs feel sturdy and high quality.
Anonymous (Saudi Arabia)
Good
“I’ve bought a lot of products from Fosi. They’re all really good.”
s
smit2680 (United States)
Haveing fun seeing what it can push 😁
Love the little unit but does get warm quick ( with 48 v 10 amp brick) . 4 ohms make it wourse of course - 16 ohms not as bad but not as loud lol. Adding a small fan next .All so got a v3 stereo to add to it soon .
Christopher (New Zealand)
BT30D Pro: the perfect 2.1 Desktop HiFi Solution!
This is my third BT30D Pro. It is a fantastically versatile unit with a crazy amount of power when used with a 48V GaN PSU. This one was used to create a genuinely portable 2.1 system, with a carry handle and speaker-retaining cargo clamps, and an Oilsky M308 DAP.
There are only two improvements needed to this amplifier (and the lesser non-Pro model) -- the addition of a High-Pass Filter with 80Hz and 100Hz switching options.
The second upgrade is a three-way power switch: OFF, RCA, and BT.
If you are looking for Most Bang For The Buck, then the buck stops right here! Buy with confidence - you won't ever regret your purchase.
Miguel (Colombia)
EXCELENTE!!
Vale mucho la pena este amplificador!!. Es compacto, el sonido es limpio, potente y tiene un buen control de volumen. Pude revivir unos viejos altavoces Technics SB F66A que funcionan excelentes, y hasta le siento mejores bajos que los que recordaba.
Solo recalco el detalle que se calienta un poco con la fuente 48V 5A. Le coloque un pequeño ventilador y va bien. Pienso colocar un subwoofer pasivo en un futuro.
Mehnas (Saudi Arabia)
Good product
I am thoroughly impressed by the build quality and the power output of this compact amplifier. It drives both my passive speakers and subwoofer effortlessly, delivering crisp highs and punchy lows. The Bluetooth connection is stable, and having precise control over the sub-bass frequency is a massive bonus for audio enthusiasts."
Enrique (Colombia)
Excellent sound, Worst heat protection implementation
First of all, I would like to emphasize that I am very satisfied with this unit in terms of sound quality, output power, material construction, size, price, and overall performance. In these aspects, I truly have no complaints.
That said, the implementation of ventilation and heat dissipation by Fosi Audio is highly problematic. The device has no effective ventilation system, as it is essentially a sealed enclosure. Consequently, the heat generated by the internal components—particularly the amplifiers—cannot be adequately dissipated through the aluminum plate, which is the sole element intended for thermal regulation. Moreover, this plate is positioned in the narrowest section of the chassis, further limiting its effectiveness.
As a result, after only 15 to 20 minutes of playback at volumes of 60% or higher, the unit consistently triggers protective power shutdowns. This makes continuous use beyond that timeframe impractical.
A redesign is urgently needed to enable proper passive ventilation without requiring owners to resort to custom modifications to correct such a fundamental flaw.
S.R. (United States)
This is nice!
Wow I love this amp already! I built my own 8” subwoofer and this powers it perfectly. It looks super clean in my setup and doesn’t take up very much space. I will definitely be purchasing more products from Fosi in the future!
Eric (United States)
Soundboard extreme
Replace a 3216 chip amp with this amazing amp. What a difference. Powers 6 drivers plus 1 sub. Thanks fosi audio.
Darko (Croatia)
My entrance to the Fosi world
I originally bought the BT30D Pro for a secondary 2.1 setup, but it slowly became one of the most useful pieces of gear in my entire system.
The subwoofer integration and control flexibility are excellent. In my current 5.1 setup I use it for center/LFE duties and it made balancing the relationship between center channel vocals and multiple subwoofers much easier than with traditional stereo amps.
What surprised me most is how effortless and dynamic it sounds. It has plenty of power, very good bass control and never feels strained, even during long listening sessions at higher volumes.
The pre-out functionality makes it extremely versatile. I ended up using it not just as an amp, but also as a control hub for different amplifier and subwoofer combinations.
For the price, the value is honestly ridiculous.
Ali (United States)
A nice and compact amplifier.
I use Cambridge Audio SX 50 speakers with SMSL 200 pro DAC with Macbook Air m4 as a streaming device. The size and audio quality of this Amp is perfect for my desktop setup.
Jeff (United States)
Simple and perfect for my patio speakers
I use this amp to power my outdoor speakers mounted in my backyard near the pool. My source is an old Chromecast Audio or Bluetooth. The set up is so simple and just what I needed. It breathed new life into my old speakers and my backyard never sounded better.
Jesse (United States)
BT30D Pro (48v)
This amplifier is powerful and can drive my speakers and subs well. I am impressed by the amount of tone control. My speakers never sounded better. I purchased another BT30D Pro (48v) to use in my other listening space.
Boloban (Mexico)
All that you ever wanted
If you always an amplifier that can power a subwoofer at this price range and as a bonus you can get a stereo amplifier all in one.
You can bring back to life you old car sound or drive a new pair of speakers you better prepare for a beautiful sound what ever your set is
Michel (Netherlands)
Very good amplifier, great sound
Use this with KEF speakers, very clear sound. Lots of power with the 48v power supply. Didn't think this much power would come in such a small package. I definitely recommend Fosi!
Jonathan (United States)
Very clear clean sound plenty powerful... BUT...
Using them with two Klipsch References bookshelf speakers and they sound amazing. However I am also using an 8" 4ohm passive sub and the sub and the sub range never is able to meet the bookshelf speakers. It can push the sub enough but by the time you hear it the bookshelf speakers are drowning it out. You need to be able to turn the two channels down or you have to use a powered sub. If there is a different option you make that can address this or has a more powerful mono channel let me know and I will upgrade.
Also the form factor and fit are perfect for me. Nice quality stuff.
