  • Upgraded Version: A new generation USB-C portable headphone DAC and amplifier, supporting up to DSD256 and PCM 32bit/384kHz decoding for a high-resolution sound reproduction. It delivers a powerful drive of up to 170mw 32Ω each channel, effortlessly powering high or low-impedance headphones with 3.5mm single-ended or 4.4mm balanced connections, immersing you in the exquisite world of music.
  • Flagship Chips: Featuring two next-generation Cirrus Logic CS43131 DAC chips, the DS2 delivers superior system-level audio performance without draining your mobile source device's battery life. With its ultra-low 1μV noise floor, minimal 0.0001% THD, high 130dB SNR, and excellent 109dB SINAD, it enables you to enjoy pure sound.
  • Easy to Use: Connect it to your audio source and enjoy high-quality music without any complicated settings. The device features independent 60-step volume control buttons, providing you with a seamless, stepless volume adjustment experience and supporting volume memory function.
  • High Compatibility: Fully supports a wide range of mainstream audio source devices. Not only can it serve as a portable DAC and headphone amplifier for iPhone 15, 15 Plus, 15 Pro, iPad Pro, and Android phones, but it can also function as an external sound card for your computer, laptop or Mac, decoding high-quality music for you.
  • Exquisite and Durable: The DS2 is crafted from solid metal using CNC machining and shock-resistant. Its sleek design offers a smooth and comfortable grip, providing a refined tactile experience. In addition, Fosi Audio pledges to provide a 24-month worry-free warranty and responsive customer service to all users.
Model DS2-2024
Output Power 128mW(SE); 170mW(BAL)
Terminating Impedance 16~300Ω
Input Mode USB Type C
Output Mode 3.5MM + 4.4mm balanced output
THD <0.0002%
SNR ≥130dB
SINAD >109dB
Noise Floor <1μV
Sampling Rate  PCM 32bit/384kHz, DSD256
DAC Chip Set CS43131x2
Compatible Devices iOS/Android/Mac/Windows
Device Weight 3.2 ounces
Fosi Audio DS2 2024 x 1
Type-C to Type-C cable x 1
USB-C to USB-A Converter x 1
User Manual x 1
Driver+Foobar installation /
Customers said this compact portable headphone amplifier delivers 'clean, detailed sound' with excellent clarity and instrument separation. It effectively powers high-impedance headphones (up to 300 ohms) from phones and computers. Some Windows laptop users reported audio dropouts. Customers praised value for money, though cable quality concerns noted.
  • 5 stars: 97 (75%)
  • 4 stars: 26 (20%)
  • 3 stars: 3 (2%)
  • 2 stars: 1 (1%)
  • 1 star: 2 (2%)
Jorge (Mexico)
Fosi Audio DS2 + HIFIMAN Ananda Stealth – Excellent Detail and Performance
The Fosi Audio DS2 has been a very pleasant addition to my audio collection. I paired it with my HIFIMAN Ananda Stealth headphones, a combination that really allows me to appreciate the quality and capabilities of this compact DAC and headphone amplifier.
What impresses me most about the DS2 is its ability to deliver a clean, detailed, and well-controlled sound. The Ananda Stealth headphones are particularly revealing, making it easy to appreciate the clarity, instrument separation, and spacious soundstage.
Listening to high-resolution FLAC recordings, especially artists like Dire Straits and Pink Floyd, is a wonderful experience. Subtle details, vocals, and instrumental textures come through with excellent definition, while the bass remains precise and controlled.
Another strong point is the DS2’s compact design, solid construction, and simplicity. It offers an impressive combination of portability and audio performance without requiring a complicated setup.
As an audio enthusiast who enjoys both vintage and modern equipment, I appreciate products that focus on sound quality rather than unnecessary features.
The Fosi DS2 is an excellent value and a great companion for the HIFIMAN Ananda Stealth. It proves that high-quality personal audio doesn’t necessarily require large or expensive equipment.
Congratulations to Fosi Audio for another well-designed product!
Central (United States)
Great product, throwaway cable
Significant compatibility issues with both a macbook and an android phone using the included USB-C cable. Once I switched to a decent cable it hasn’t been an issue at all.
The sound is fantastic.
J (United States)
Clean sound coming from DS2
I’m impressed with the sound coming from DS2. Compared with the built-in audio of my laptop the DS2 produces cleaner sound. You just need a good high-sample-rate audio and you will be listening to good hifi music. Thank you Fosi audio!
David (Sweden)
Fosi Audio DS2 Dongle DAC Headphone Amplifier
Evgenii (Georgia)
Windows laptop incapability
I have sound dropdowns on my Windows laptop.
James (United Kingdom)
I feel like I have new ears!
I bought this after feeling dissatisfied the audio from my laptop - I have Sennheiser HD650 cans which I've had for close to 20 years and felt the audio coming from the 3.5mm output was flat and wanted an external DAC to see how it would improve. AND HOW! Honestly, music sounds how I remember hearing it 30+ years ago, it's like a veil is lifted from even lower quality (256k) encodes. I predominantly listen to rock, pop, electronic and 'alternative' music and everything has improved top end, clarity and soundstage. From a device that is so low in price (I paid 45GBP) I suddenly have the best headphone experience I've ever had - and that's about 40 years of experience! I will certainly be investigating Fosi's other products as I have a lifetime of physical music I'd love to rediscover.
Melvin
Quality product does not disappoint.
Giorgi (Georgia)
Fosi ds2
Good quality. Good design. Good sound. Good amp. Fast shipping.
Giorgi (Georgia)
Fosi ds2
Silvio (Brazil)
High Enjoyable Audio
Even at standard quality settings—44.1 kHz and 16-bit—it enhances tone separation, increases overall clarity, and produces a well-defined sound. Paired with mid-to-high-end headphones like the Philips SHP9500 or Audio-Technica ATH-M40x, it reveals the music's nuances and details. It is a highly rewarding experience; I really enjoyed it and now listen exclusively using this setup.
Silvio (Brazil)
Even at standard quality settings��44.1 kHz and 16-bit��it enhances tone separation, increases overall clarity, and produces a well-defined sound. Paired with mid-to-high-end headphones like the Philips SHP9500 or Audio-Technica ATH-M40x, it reveals the music's nuances and details. It is a highly rewarding experience; I really enjoyed it and now listen exclusively using this setup.
Anonymous
Worked OK for me!
LIJohn (United States)
Nice DAC
It's a pretty good DAC/amp for the price. It sounds and functions well. I mainly like that it has an independent volume control from the playing device. Although, be careful, it says in the literature it doesn't work independently with all devices.
Nice DAC
Charles (United States)
Good portable headphone dac, but I'm using it for something else.
The device has the potential to be a great DAC, but my use case is a little different. I'm assembling a 'portable' music player to put in an automobile, using two Raspberry Pi, 8 batteries, an external wireless adapter and the Fosi Audio DS2 as the DAC. The finished device will be a little smaller than a shoe box. I wanted something simple, that didn't need a phone app for tuning, and the DS2 serves that purpose well. I was also something that had little to no amplification, because I'll be connecting to an automotive audio system. I'm not sure if double amplification is good or bad. Distortion is bad, and the DS2 should be pretty clean. It's not done yet, so I can't say that it's a 100% solution, but testing in the house is going well so far.
Muhammad (Pakistan)
Muhammad (Pakistan)
William (United States)
Not An Audiophile But Definately Hear The Difference
I recently retired my 20 some year old Sennheiser headphones and replaced them with a new pair and expected a big difference in what I was hearing but not much. I thought that I might get better performance if I used a DAC different than the default DAC that came with my computer. I did a lot of review comparing and decided my best bet for performance and value was Fosi's DS2. There were no issues plugging it into my Dell and wow! What a difference! Very happy with this purchase.
Raymond (United States)
Martin (Switzerland)
Dac DS2 portable
Excellent !!
Dac DS2 portable
Excellent !!
Frank (Canada)
A Clear Step Above the Apple Dongle
I use the DS2 to listen to “lossless” streamed / downloaded music from Apple Music. I'm listening on my iPad or iPhone, using excellent open-back phones from Grado. The DS2 is a step-function improvement over the Apple dongle/dac. I hear instruments with great clarity and new-found sounds from familiar music files. The DS2 is well-worth what paid for. There are still iPhones in use with lightning rather than USB-C interfaces; I wish Fosi had included a USB-C to Lightning short cable.
Frank (Canada)
I use the DS2 to listen to ��lossless�� streamed / downloaded music from Apple Music. I'm listening on my iPad or iPhone, using excellent open-back phones from Grado. The DS2 is a step-function improvement over the Apple dongle/dac. I hear instruments with great clarity and new-found sounds from familiar music files. The DS2 is well-worth what paid for. There are still iPhones in use with lightning rather than USB-C interfaces; I wish Fosi had included a USB-C to Lightning short cable.
Sauro (Italy)
Fosi Audio DS2 Dongle DAC Headphone Amplifier, I really liked the sound and it can drive my Fosi audio headphones with balanced cable with more than enough volume
Sauro (Italy)
