  • Small but mighty! Fosi Audio M04 is a 100w mono-channel class D subwoofer amplifier, with a SUB/PBTL switch you can select a subwoofer bass amplifier or full frequency mono amp, can be connected to an active/passive subwoofer and passive speaker.
  • The power switch was integrated into volume control, we made it small but supply an in-wall or stand-alone subwoofer the power it needed so you can experience room-shaking low-frequency impact (bass) on movies and music soundtracks.
Fosi Audio M04 Amplifier Subwoofer Amp 100W With Bass Power Amplifier For Home Passive Speaker
  • Input Interface: RCA input
  • Output Interface: speaker’s output
  • THD: ≤ 0.02% (1KHz, 1W)
  • Output: passive subwoofer/speaker
  • Input Voltage Range: DC 12V - 24V
  • SNR: ≥ 102dB
  • Terminating Impedance: 2Ω - 8Ω
  • Max Power Output: 100watt @3Ω
  • Input Sensitivity: 600MV
  • Net weight: 175g
  • Dimensions (H * W * D): 103 x 57 x 43MM (4.06 x 2.24 x 1.69’’) includes knobs
  • Frequency Response Range: 20Hz-20KHz(±3db)
  • Bass Frequency Range: 20Hz-200Hz
Package Includes
  • Fosi Audio M04 Subwoofer/Mono Amplifier x1
  • Power Adaptor x1
  • AC cord x1
  • User Manual x1
    Compare with similar items
    Customers praised this subwoofer amplifier as "punching above its weight class" with excellent value and reliability. It powers passive subs and speakers effectively, with adjustable frequency controls. Shoppers noted it works well for desktop and home theater setups at close range, though some suggest more power for larger distances or 8-ohm speakers.
    • 5 stars: 9 (100%)
    • 4 stars: 0 (0%)
    Destiny (United States)
    Works!
    Partner has a 3ohm passive subwoofer from an old setup, powers this and connects to his receiver just fine!
    j
    john (United States)
    AMP DOES WHAT ITS SUPPOSED TO DO.
    NICE AMP WORKS WELL.
    ERIK (United States)
    Punching above its weight class
    I never understood that desktop audio equipment has come so far and can do so much. Definitely do your research, but it appears that Fosi has everything you need to integrate a wonderful system. I started with a 30 D pro and would probably start over with components in the same family or that are capable of triggering each other for one start up however, I’ve just been experimenting and had amazing results Next I’ll be getting a DAC that will probably not be fosi and will be a DAC A7, but like I said, do your research to find out what fits and compliments each other the best and it appears that with nice efficiency speakers, you can do a lot with small components.
    Kolda (Czechia)
    Best amp
    Best amp for subwoofer
    Larry (United States)
    Using to drive Boston center channel surround
    Not using to drive sub. I am about 8 ft away and can adjust volume loud until it is annoying or uncomfortable. It works for my application. It would also work for computer. If you are 12 ft away and want to drive sub or music ,I would suggest saving up a little more $ and getting something else more powerful.
    Especially if driving 8 ohm speaker.
    FRANCO (Italy)
    OTTIMO AMPLIFICATORE
    complimenti a Fosi per la veloce spedizione, l'imballaggio ed il prodotto conforme alla descrizione. Ho usato l'amplificatore per sostituire la piastra di un subwoofer attivo che si è danneggiata. L'M04 pilota con facilità il woofer da 25 cm con impedenza misurata di 3,5 ohm con un controllo del volume che al massimo metto a metà corsa. I bassi sono bene regolati ed escono con potenza e precisione. Sono contento dell'acquisto anche perchè è facile da collegare e da usare e non scalda. Grazie Fosi - ottimo prodotto.
    Tony (United States)
    Perfect first sub pre-amp
    I needed a sub pre-amp for a basic home audio setup, and after some research, this seemed to offer the best value with the right inputs & outputs. Nothing else really came close.
    Very happy with it so far, the bookshelf speakers already sound better for not having to process the low frequencies.
    RedWingsRed (United States)
    Great little Sub Amplifier.
    This is a great little 100w home theater sub amplifier. It is always left on and hasn't been turned off in 3+ years and it hasn't skipped a beat, literally. I hooked it up to a Logitech 165w Sub woofer that used to have its own built in amplifier, but the speakers that connected to the Sub to control it weren't included. This little amplifier and Sub work great together and sound amazing, it rattles my living room! The adjuster nob for frequency is a must have and the fact that it has an option to run a sub or a regular speaker is great. I set it to sub and adjusted the frequency to about 90, about half of its capabilities and it hits the low lows and everything in-between, it sounds amazing. It powers this 165w sub perfectly. I love the theater sound I get when watching movies and listening to music? Wow. Was definitely worth the price, I love it. You won't regret buying it. 3 years I've left it powered on and still going strong. What a buy. FOSI makes quality, the thing is built really well and it feels made well, it has some solid weight to it. Really built well. I found my brand and I know who to go to in the future. Thank you Fosi for making such a great product. 👍 100 🌟 🤩
    Edwin (United States)
    M4 was just what I needed.
    Good little amp.
