  • Noise suppression: Through the combination of filter capacitors and inductors, the power filter effectively suppresses conducted and radiated interference, reducing the impact of electromagnetic interference on devices.
  • Power purification: Filters out high-frequency noise and harmonics from the power supply, providing a stable and clean power signal, and enhancing the performance of audio and video equipment.
  • Device protection: Reduces the impact of power surges and spikes on devices, extending their lifespan.The
The DC filter not suitable for BOX X5
The DC power filter reduces noise and improves audio quality. Customers said it lowers the noise floor, creates "smoother, clearer and purer" sound, and adds detail and warmth. Many reported measurable noise reduction. Some noted the price point offers excellent value, though a few requested more technical data and better cable quality.
  • 5 stars: 66 (87%)
  • 4 stars: 5 (7%)
  • 3 stars: 3 (4%)
  • 2 stars: 1 (1%)
  • 1 star: 1 (1%)
Paul
Nice DC filters
I use these with all of my Fosi gear, it actually works. The noise level is noticeably lower when the volume level is cranked to max (with no music playing). I appreciate this inexpensive upgrade for the power supply
Paul
Nice DC filters
Michael (United States)
This is excellent.
Periodically, I used to experience a light buzzing sound with my xduoo xd05 pro when using my linear power supply. I don’t have no clue why it emits but when I physically touch it with my finger, it goes away. Well I don’t have time for that. I bought this and no buzz whatsoever. In fact, it sounds clearer and much better. Not sure if it’s placebo but I don’t think so. Buy it!!!!
This is excellent.
Periodically, I used to experience a light buzzing sound with my xduoo xd05 pro when using my linear power supply. I don��t have no clue why it emits but when I physically touch it with my finger, it goes away. Well I don��t have time for that. I bought this and no buzz whatsoever. In fact, it sounds clearer and much better. Not sure if it��s placebo but I don��t think so. Buy it!!!!
h
hiwata
Very cost-effective product
I use it with ZA3. I measured what effect this product has. The second photo is without it, the noise is 180mVpp. The first photo is with it, the noise went down to 80mVpp.
In my environment, I was able to reduce noise by more than half. I think this is a very cost-effective product.
h
hiwata
Philipp (Germany)
Smooth trebles more contour in bass
It’s not a big investment and so I gave it a try. I’ll keep them. I bought two. For each device because I listen with two monos ZA3. Music coming from ZD3 with op amp Burson v7 vivid.
Philipp (Germany)
It��s not a big investment and so I gave it a try. I��ll keep them. I bought two. For each device because I listen with two monos ZA3. Music coming from ZD3 with op amp Burson v7 vivid.
Terry (Canada)
Fosi Audio DC Power Filter
Warren (Australia)
Jean-Pierre (Switzerland)
Schwer zu bewerten
Im Rating gebe ich dem DC Power Filter „nur“ 3 Sterne. Nicht weil die DC Power Filter schlecht wären, sondern weil die klangliche Wirkung schwer nachvollziehbar und zu bewerten ist. Klanglich schädlich sind diese DC Power Filter sicher nicht. Allerdings, bringt der Einbau von den Burson Vivid V7 /Classic Op-Amps in den ZA3 (mono) Endstufen eine eindeutige klangliche Verbesserung. Sehr empfehlenswert.
Daniel (United States)
Fosi Audio DC Power Fileter Review
Application of the DC filters to 48V 5A PSU for Fosi ZA3 mono blocks made some audible difference. Lower noise floor. For its price, it is definitely worth it.
Anonymous (Latvia)
Nice
Nuno (Portugal)
Test it with oscilloscope, and it really decresse noise and ripple tension.
Jeff, (Australia)
I have only tried one filter so far, on a ZA3. The results are very pleasing, with the ZA3 sounding much smoother, clearer and purer. I am yet to try my second filter, but will get to that with my V3 Monos soon. A good product, and purchase.
Filter review
The filters brought detail and more depth and warmth, not an ee just my opinion
Gary (United States)
Filter review
Anonymous (Germany)
Good quality and an improvement in my chain.
Igor (Norway)
Powersupply filter
It improved sound. Sound is more natural, high tones are not so bright any more. I use it with my zd3 dac.
Igor (Norway)
Powersupply filter
Dave (United States)
I have purchased 7 of these EMI/RFI DC filters. They easily reduce noise by half. I use most on SMPS (10A 48V) that feed 300W+ class D amplifiers.
Randi (United States)
Supporting Data Needed
I bought one strictly based-on FOSI's reputation and because I own 7 other FOSI hardware.
I am not certain what this "DC Filter" exactly filters out and how much ("insertion loss" (I.L.) measurements):
(1)I.L. data under max/min specified voltages (12V/55V)?and max/50% (10A) loaded configurations across DC-10MHz?
(2)Voltage drop measurements?
(3)Why minimum 'DC IN' is >12Vdc, when you make audio hardware with 5Vdc inputs?
RandiO (United States)
Pixie Dust?
Hey, FOSI,
This owner (of over 7 of your products) thinks that it is a disservice what you are peddling here. This product as advertised is like saying pixie dust makes your audio system sound better. The least you can do, is affix some objective (insertion loss) performance data to the page so that we can actually say "Hey look, this thing will really provide -60dB[?] of insertion loss at 2kHz[?]!"
But I bought one anyways, because of nothing but your reputation, NOT because it's a performer at 10MHz[?]! Do I have to open its case to see build quality and schematic?
Anna
Fosi D3 Music Streamer
So far very content with my new streamer 😃 Have a few more cables to try ... Love the output choices available 😊🎶🎵
Anna
So far very content with my new streamer ?? Have a few more cables to try ... Love the output choices available ??????
