  • Connector Material: Zinc alloy with chrome plating
  • Compatible with: ZA3, ZD3
  • Not compatible with: AES/EBU connectors
  • Premium Construction: Made with nylon braiding, PVC coating, copper foil shielding, anti-pull threads, and oxygen-free copper braiding shielding for superior durability and performance.
  • High-Quality Connectors: Features zinc alloy connectors with chrome plating, ensuring excellent conductivity and corrosion resistance for long-lasting use.
  • Balanced Audio Transmission: Designed for balanced audio signal transfer, it effectively reduces noise and interference, delivering high-fidelity sound over long distances.
  • Versatile Compatibility: Compatible with ZA3 stereo amplifier and ZD3 DAC Preamp, good for professional audio setups like microphones, mixers, and audio interfaces.
  • Compact and Space-Saving: The 0.3M (1ft) length is perfect for tight spaces, ensuring a neat and organized setup without excess cable clutter. Ideal for desktop microphones and compact audio interfaces.
  • XLR Cable*2
Premium XLR cables praised for excellent build quality and value. Customers said they deliver "crystal clear" signal with "absolutely zero hum or interference." Many noted immediate sound improvements with "more clarity and separation." Well-constructed with sturdy connectors and braided design. One complaint about color mismatch and delivery time.
  • 5 stars: 84 (91%)
  • 4 stars: 7 (8%)
  • 2 stars: 1 (1%)
Yankele (Ecuador)
This are premium XLR cables!
Got this to connect my ZD3 to my prramp and the result is obvious: more clarity and separation. This cables are extremely well made, heavy and braided. I choose the small ones to fit my preamp and want to avoid cables clutter.
Andrés (Chile)
High-quality XLR cables with a perfect fit
I purchased these XLR cables to connect my Fosi ZD3 DAC to the ZA3 amplifier, and they work perfectly.
The connectors fit securely without being overly tight, and the cable itself feels durable and well made. There is no audible noise or interference, and the balanced connection performs exactly as expected.
Andr��s (Chile)
K. (United States)
Fosi Audio XLR
Great XLR cable from Fosi Audio. The build quality is excellent with sturdy connectors and a flexible, durable jacket. Signal transmission is crystal clear with absolutely zero hum or interference. Highly recommended for the price!"
Kendi (United States)
Fosi Audio XLR
Pavel (Israel)
bar code
Hi,
I bought these cables from a local supplier but they were just in a regular white bag. Could you tell me the bar code for this product please?
Thank you
Pavel (Israel)
bar code
Hi,
Thank you
Sanjay (India)
Fosi XLR Cable - Solid Built
Built quality of the cable is very good. Don't waste money on sponsored or mentioned by YouTube influncers.
Sanjay (India)
DGJ (The Netherlands)
Great
Great
Great
Great
Ralph (Canada)
XLR cables.
The XLR cables are good. I should have just bought the longer ones. My bad. 😕
Ralph (Canada)
XLR cables.
The XLR cables are good. I should have just bought the longer ones. My bad. ??
George (Qatar)
No 1 product in
I would say, its an amazing product
George (Qatar)
No 1 product in
S.G. (Spain)
Excelente construcción
Terminación de lujo. Muy recomendables.
S.G. (Spain)
Excelente construcci��n
Terminaci��n de lujo. Muy recomendables.
Forrest (New Zealand)
Solid Cable
Excellent cable but I wish it was just a little longer as it doesn't reach from my ZA3 to my BlueSound Node Icon without stressing it, but I don't want the other option which is way too long for me at 120cm! I suggest Fosi make one in between, say 50cm!
Tim (Canada)
Quality XLR
Great cables, very well made.
Edward (Canada)
Fosi XLR Cables
I ordered the 1' cables, as my components are closely stacked. These are well made cables that fit the sockets quite well and tightly. I am very pleased with them.
Jason (Canada)
Noisy cables.
Used these to connect my fosi audio S3 to amplifier and noticed a hissing sound at low volumes. Replaced with known good digiflex cables for now and the noise is gone. Went back and forth twice to confirm that it was indeed the cables and not a poor connection etc. Contacted fosi for a replacement or refund and after trying to help me out they ended up sending me a refund. Good customer service.
Joe
Well made. Good value.
Salvador
The cable arrived in black not like the picture and the delivery timeline was very long and disappointing.
Igor (Slovakia)
Great product.
Robert (United States)
Wow, immediate difference noted from my RCA cables!!
Wow, immediate difference noted from my "high-end" RCA cables. Louder immediately and absolutely no noice. Am feeding Schiit Mjolnir from Cambridge Audio DAC. And at such a great price, well done FOSI!!
