  • Material: Made of 14AWG oxygen-free copper audio cable, ensuring high-fidelity sound.
  • Plugs: Precision CNC machined, solid copper gold-plated banana plugs for enhanced electrical conductivity.
  • Compatibility: Perfectly compatible with Fosi Audio amplifiers, providing stable connections.
  • Design: With a durable multi-braided construction, it can withstand years of use.
  • User Experience: Easy to use and offering secure connections to bring a pure audio experience.
  • Package Includes: Two Speaker Cables with 8 Banana Plugs
Oxygen-free copper speaker cables praised for "excellent quality" and "great price." Customers said they're "well built" with robust braided construction and smooth connectors. Sound quality described as "great" and "fantastic." Some noted plugs can loosen from tips and cables may be short. Overall highly recommended.
  • 5 stars: 90 (86%)
  • 4 stars: 12 (11%)
  • 3 stars: 3 (3%)
They look and work fantastic
I have a set of these and have zero complaints from them. The sound is great and they are very high quality.
I would definitely recommend them if you want all your kit to be Fosi Audio. They just feel great in the hand and hopefully will last
Guillermo (United States)
DocHouse (Germany)
outstanding interconnect
like the Eurotunnel or the Golden Gate Bridge, no better connection
Thank you Fosi Team
DocHouse (Germany)
Thank you Fosi Team
DGJ (The Netherlands)
Get easy loose
The plugs get easy loose from the tips. Cables are the short.
Anted (Italy)
Ottimo acquisto
Ho acquistato una coppia di cavo audio definitivo per gli amplificatori audio Fosi (2 paia). La qualità è ottima ed i materiali sono di qualità ed i connettori a banana sono ben attaccati al cavo. La qualità è anch'essa superiore alla media. Molto soddisfatto dell'acquisto, ne ho acquistato altri 2.
Anted (Italy)
Ottimo acquisto
Ho acquistato una coppia di cavo audio definitivo per gli amplificatori audio Fosi (2 paia). La qualit�� �� ottima ed i materiali sono di qualit�� ed i connettori a banana sono ben attaccati al cavo. La qualit�� �� anch'essa superiore alla media. Molto soddisfatto dell'acquisto, ne ho acquistato altri 2.
Dario (Italy)
Eccellente!
Steve (United Kingdom)
Nice Cables
Excellent quality cables very happy
Dario (Italy)
Good quality and shape
At first sight those cables show good quality material, easy to connect allo to my vintage speakers.
Carlo (Italy)
Perfetto
Stephen (United Kingdom)
Quality cables
Daral (Australia)
Fosi Audio Oxygen-Free Copper Speaker Cables
They seems really good, but I’m no expert. Great for the price and sound. I’m using the XLR cables from my Rega Planner P1 Plus record deck into my Fosi ZA3 amp. With Q Acoustic 3030i speakers.
Mike (United Kingdom)
Great quality for the price
Good quality for the price, robust braided cables and smooth screw on connectors. Braiding inside of the connectors should be fused/melted to stop them wearing but for the price these are great
Christoph (Germany)
Passende Qualität für den Preis, nur doch etwas zu Kurz. Behalte sie aber trotzdem.
Simon
Good quality and stay in place well.
Cody
Great! Love that you can take off the longer cover pegs to reveal the wire for older speakers!
Anonymous
Really good
Really good product
U
Uwe (Germany)
Gut Verarbeitet aber die längen der Kabel sollte auch länger angeboten werden.
Muralidharan (United States)
JEAN-PIERRE (France)
Très bons câbles. Apportent plus de définition par rapport à mes anciens câbles (standards). Il faudrait juste prévoir des longueurs un peu plus grandes: jusque 3 m par exemple (j'ai dû commander dans une autre marque du coup pour une des enceintes - rendu compte au dernier moment que 1m80 c'était trop court).
C (New Zealand)
Excellent product
Very good
George (New Zealand)
Excellent product
Very good
Thomas (United States)
Fosi Audio Oxygen-Free Copper Speaker Cables��2 Pairs��
Macdonald (Canada)
Macdonald (Canada)
Aurelien (Australia)
Perfect product
Doing very well what it supposed to do
Perfect product
