HIGH PERFORMANCE - The built-in low-pass filter removes high-frequency noise, resulting in a purer and clearer signal. The frequency response range is 20 Hz - 250kHz, with THD ≤ 0.04%, SNR ≥ 98dB, and an input sensitivity of 775mV. It delivers the warm tone and powerful bass you desire
BASS BEAST - This mini bass amplifier is designed for gamers, movie buffs, and music lovers who want to feel the beat. It can connect to a powered and a passive subwoofer and includes a knob for adjusting low frequencies (30Hz-260Hz) to your preference
EXCELLENT CHIP - Features the Texas Instruments TDA7498E chip and NE5532 op-amp. No pop, built-in speaker protection circuit, and silent when not in use. With a maximum output power of 220W, it is ideal for large subwoofers
POWERFUL SOUND - This subwoofer amplifier, designed for HiFi bass aficionados, generates powerful audio with smooth and pure bass. It will breathe new life into your old speakers, enabling you to fully immerse yourself in rich, dynamic sound
WHAT YOU GET - Fosi Audio TP-02 subwoofer amplifier*1, 24V power adapter*1, Use manual*1. This sub amplifier comes nicely packaged with a solid feel to the case, controls, and connectors
Customers praised this compact subwoofer amplifier for its exceptional power and value. One customer noted it "can easily overdrive" speakers at 60% and stays "cold to the touch." Shoppers highlighted its excellent performance with bass shakers and racing simulators, calling it "worth every penny" and a great replacement for larger amps.
  • 5 stars: 11 (85%)
  • 4 stars: 2 (15%)
DM (Saudi Arabia)
Highly recomended.
Worth every penny. Paired with Fosi BT20A PRO and polk audio speakers. Sounds amazing.
DM (Saudi Arabia)
Highly recomended.
Alan (United States)
Great buy!
Replaced 280 buttkicker amp with this for under 100 bucks. My racing SIM is back in action thanks to FOSI! I will definitely buy from these folks again!
RAMESH (India)
Worth buying
Super
RAMESH
Worth buying
Super
EchoAudio (United States)
good little amp
good little amp
Eric (United States)
Packs a punch, don't even think twice about getting this!
I hooked this into a jbl 160 with a failed plate amp that houses an 8" 4ohm svc subwoofer. This little beast can easily overdrive that woofer at 60%. Played for about 10 minutes in the garage and the unit was cold to the touch. Next I'm going to try two 12" dvc subs at 2 ohm. I have no doubts that it will be up to the task. Very impressed. Crazy how far amp technology has come since I was a kid. Only test now will be longevity. I'll try to update if anything changes.
Dorian (Romania)
Excelent
Very powerful for bass shaker Dayton Basx A300 . Good good product
Dorian (Romania)
Excelent
Sam (United States)
Great amp for my Lii audio w21 woofer
This replaced a cumbersome plate amplifier and I lost nothing in performance
Sam (United States)
