Video laden:
Built on User Voices
  • Input: RCA x2 and XLR
  • Output: RCA, XLR, SUB
ZP3 & P4 Comparison
Channel: 2.0
Input: RCA x2, XLR
Frequency Response
XLR/RCA:
20Hz-20kHz (±0.2dB)
80Hz-20kHz (±0.2dB)
120Hz-20kHz (±0.2dB)
SUB: 20Hz-200Hz (±0.2dB)
Balanced Output (XLR)
SNR: ≥ 112 dB
Dynamic Range: ≥ 112 dB
THD+N: ≤ 0.0007%
Noise Floor: ≤ 6μV
Single-Ended Output (RCA)
SNR: ≥ 115 dB
Dynamic Range: ≥ 115 dB
THD+N: ≤ 0.0008%
Noise Floor: ≤ 4μV
  • Fosi Audio ZP3 x 1
  • IR Remote Control x 1
  • AC 110-240V Power Cord x 1
  • 12V Trigger Cable x 1
  • User Manual x 1
From $199.99
Fosi Audio ZP3 Preamplifier
Preamp
RCA x2, XLR
RCA, XLR, Sub-Out
Bass & Treble Control
≤ 0.0007%
≥ 115 dB
From $99.99
Preamp
RCA x3
RCA, Pre-Out
≤ 0.003%
Preamp+Headphone Amp
≤0.02%
≥103dB
Customers praised this preamp for exceptional sound quality, delivering clarity, detail, and impressive stereo imaging. "Sounds great," said shoppers when paired with mono amps. The high-pass filter and balanced connections were frequently highlighted. Some noted hissing issues and limited remote functionality, while the volume knob design received mixed feedback.
  • 5 stars: 67 (80%)
  • 4 stars: 13 (15%)
  • 3 stars: 2 (2%)
  • 1 star: 2 (2%)
Jorge (Mexico)
The Missing Piece in My Audio System!
As an audio enthusiast and proud owner of several Fosi Audio products, I can confidently say that the ZP3 was exactly the component I needed to complete and organize my audio system.
In my current setup, I use a WiiM Ultra as my primary music streaming source and a Yamaha TSR-7790 for home theater. Both are integrated through the Fosi Audio ZP3, which serves as the central hub for signal selection and management.
For amplification, I use a Rotel RMB-1575 power amplifier, paired with my Monitor Audio RX6 speakers.
What I appreciate most about the ZP3 is its versatility. It allows me to integrate different audio sources into a single system while keeping everything organized, convenient, and focused on sound quality.
Its build quality, design, and functionality reflect the positive experience I've had with other Fosi Audio products. It's one of those components that, once integrated into your system, makes you wonder how you ever managed without it.
The ZP3 has now earned its place alongside my growing collection of Fosi Audio equipment. This brand continues to impress me with its commitment to delivering excellent performance, thoughtful engineering, and outstanding value.
Congratulations to the Fosi Audio team! The ZP3 is an excellent addition to any hi-fi or home theater setup that needs flexibility, control, and seamless integration.
Highly recommended!
Gibralthor (United States)
A Gem, Op-AMPs rolling
For those audiophile, if you plan to use the Dual Staccato op-amp
it does not work with the ZP3.
ERIK (United States)
Amazing
Running the ZH3 DAC into the ZP3 followed by dual ZA3’s in mono, Polk ES15’s and a Dayton powered sub. XLR connections and 12v switching. The sound is insane. Stick with neutral speakers like Polk, and you will hear music in your home in a way you likely have not before.
Massimiliano (Italy)
Un upgrade necessario
Ho acquistato il FOSI Audio ZP3 Preamplifier per sostituire il precedente FOSI P4 Mini Preamplifier in quanto ho espanso il mio impianto e avevo necessità di una uscita per il subwoofer attivo (FOSI SW10), che il piccolo P4 non aveva. Posso dire che la qualità generale del prodotto è ottima e in linea con gli standard a cui FOSI ci ha abituato. Per quanto riguarda la versatilità e funzionalità del prodotto ovviamente è quasi perfetto per le mie esigenze. Avrei preferito ci fosse anche un ingresso ottico, magari in alternativa all’ingresso bilanciato o comunque da selezionare con un commutatore sul retro. Per il resto la qualità del suono a mio avviso è molto simile al precedente P4 e, in considerazione del prezzo pagato mi reputo soddisfatto delle prestazioni fornite.
Aaron (United States)
Secret Talent of the ZP3
What not many are talking about is how exceptional this preamp is at converting balanced to unbalanced and vice versa . I originally bought this for my main hifi but it added unvetted cables to my perfect synergy chain and ended up removing the ZP3. I almost sent it back when I tried it on my desktop system where I was using the streamer's DAC to feed desktop speakers. I used the ZP3 to pull balanced line out of my R2R headphone DAC to my speakers' single ended inputs. Subtle improvement, but that slight change was enough to make the sound more convincing and allowed my speakers to disappear so I can just hear the music like in my main system and headphones.
Enrique.O. (Spain)
Magnífico pre-amplificador.
En combinación con una etapa Hegel H20 y unas cajas artesanas basadas en Davis Acustics y, como fuente Eversolo DMP A6 Máster Edición (Streamer, mini disc SONY, CD EMOTIVA) todo cableado balanceado. Resulta un conjunto medio alto, con una claridad, definición y profundidad que hace las delicias de cualquier audiophil.
Louis (United States)
Excellent addition to my Fosi setup.
Running a set of ZA3’s with a ZD3 and a P5 phono pre. The ZP3 is quiet, dynamic, and noticed a wider soundstage when introducing. Very happy with the product, thank you.
Nikolai (Norway)
Good
I tested this out from a friend and I was suprised by the connectivity and quality, would recommend to anyone wishing to get into Hifi
PotetBananSkall (Norway)
Looks great works greater
I bought this ZP3 preamp recently and i was pleasantly surprised by the quality it has. The quality and versatility is great and I recommend it to others
Anonymous (Croatia)
Fantastic sound
I have a ZP3, two ZA3s in mono mode and a ZD3 Dac.
Fosi devices are fantastic. The sound they provide is excellent. I am very happy. Thanks Fosi.
z
zoxy1955@gmail.com (Serbia)
ZP3
Odlicno, verovatno najbolje do sad pretpojacalo od Fosi.
Potpuno balansirani, izvanrednog zvuka, idealno za seriju Z: ZD3, ZH3, ZA3
Iskrena preporuka
Eduardo (Peru)
Impresionante producto, muy contento
Realmente sorprendido con la calidad de este producto, cumple con todo, se nota la calidad de los acabado
Cesar (Mexico)
ES mi primer equipo separado. Lo tengo acoplado a dos amplificadores V3 mono y un DAC ZD3. Me gusta el rendimiento, lo tengo conectados por XLR. Lo único que podría pedirse es algún indicador lumínico de volumen. El control puede controlar otros equipos de la marca.
Marquitta
Darrin
Hreinn (Iceland)
Ilse
They have faced a problem due to duplicate shipping and have behaved super well. At the moment, we don't know what the error was.
Sidney
Fast delivery, satisfied. I am using the Eversolo DM6 product and have not yet connected the additional preamplifier due to lack of experience. Therefore, it is difficult to comment on its performance, but based on user reviews, it seems satisfactory.
Ray
Very good, I like the performance too. It's convenient because it has both trigger and output.
César (Mexico)
Excelente presentación
Vamos a probar todo el conjunto.
Krzysztof (Poland)
comfortable
- the preamplifier is "transparent" - with factory settings
- I don't use subwoofer - I left the high-pass filter open
- I connected two ZA3 amplifiers to the preamplifier using XLR - this is a very good set
- I use the eversolo DMP A-6 gen 2 as a source
- thanks to ZDA3 I could turn off the preamplifier in eversolo
- which gave a surprising effect
- now the sound is very juicy, powerful and direct
- and the operation of the set has become simpler and very traditional, simple and old-fashioned
- Since the ZDA3 has a high-pass filter, I am considering buying a subwoofer for my system
- this is the next stage
RAFAEL (Spain)
en perido de ensayo
por el momento muy contento, estoy con el rodaje lo he emparejado con un ampli en estéreo ZA3. Redescubriendo los matices de mis CDs y lo malo es que descubres lo mal grabados que estan algunos de tus CDs en la colecion jajajajaj. proximamente lo conectare en alto y en bajo a un subwoofer. ya contare mi experiecia.
