Fosi Audio 24V 4.5A Power supply for TDA7498E TPA3116 TAS5613 Amplifier
- Precio habitual
- $19.99 USD
- Precio de venta
- $19.99 USD
- Precio habitual
$19.99 USD - Precio unitario
- / por
- AC110V-230V input;
- DC 24V 4.5A 6A 8A output;
- Connector size: 5.5*2.5mm
- Power adapter for class d amplifier;
Got it as a replacement for TB10A, and I can hear the power supply. Yeah it's faint, but when it's on your desk you can hear it, and it gets annoying. When it's just plugged into the wall it's a faint fast clicking sound, not too loud, but when you plug it into the amp it's a high frequency whine.
I have two other Fosi power supplies from similar amps and same specs, and they are absolutely silent, you can't hear anything, even when you put them against your ear. I also have another cheap power supply that makes the same whining sound I was going to use originally, but thought that if I got a genuine replacement from the manufacturer it would be good as new, but apparently not.
I got in touch with Fosi to explain that the power supply for my amp had failed.
``although it took over 20 days to arrive, it’s here now and it works.
As described and working great.
Fosi Audio 24V 4.5A 6A 8A Power supply for TDA7498E TPA3116 TAS5613 Amplifier
