- Retro Design, Modern Craftsmanship
- 12 Hours. Music Nonstop.
- Hi-Res Lossless Audio Quality
- Expandable Storage & Dual Connectivity
Minimalist UI, Zero Distraction
Designed for pure audio enjoyment. The simplified user interface eliminates complex menu navigation, allowing you to quickly browse your favorite playlists and immerse yourself in high-fidelity music instantly.
Refined Touch & Durable DesignFeatures a premium anti-glare AG glass back panel with a smooth, fingerprint-resistant finish. Crafted for comfort and everyday portability without sacrificing elegant aesthetic detail.
Powered by the high-performance CS43198 DAC chip, delivering crystal-clear sound, dynamic balance, and rich studio-grade detail to revive every beat of your lossless audio collection.
12-Hour Continuous Playback
Equipped with an efficient power system that provides up to 12 hours of uninterrupted listening on a single charge. Perfectly built to accompany your daily commute, workouts, or late-night focus sessions.
|Supports expandable microSD storage up to 256GB to hold thousands of music files. Seamlessly connect via stable SBC Bluetooth wireless or classic 3.5mm wired headphone jack for total listening freedom.
Fast,Free Delivery
Free Shipping In 3-10 business days On Orders.
Global support
Our support team can help with product setup, order questions, and after-sales service.
In a world built to keep you scrolling,
choose an experience made to keep you listening.
Less distraction. More music.
Music doesn’t need a feed.
It needs a moment.
Hear Every Detail. Feel More.
Powered by the CS43198 DAC, high-resolution
lossless audio brings your music to life with clarity, depth, and detail.
Your Music Library, In Your Pocket.
16GB or 64GB Memory Card Included.
Expand storage up to 256GB and keep more of your favorite music with you.
Product Specification
Audio DAC Chip1× CS43198
Output Power129 mW
Output Interface3.5mm Single-Ended
SNR127 dB
Display2-inch TFT LCD, 320×240 Resolution
MaterialFull-metal Housing, 5-Axis CNC Precision Machining
Weight≤75g
Dimensions97 × 47 × 10.6 mm
Bluetooth CodecSBC
MEMORY CARD16GB / 64GB Options
Audio Formats SupportedMP3, FLAC, WAV, APE, M4A, DSD
Does DAP Neo support streaming apps such as Spotify and Apple Music?
DAP Neo is designed for local music playback. It does not support Wi-Fi, online music services, or the installation of streaming apps. Download the files to your memory card to enjoy the music.
Can I connect Bluetooth headphones or speakers?
Yes. DAP Neo supports SBC encoding and can send audio to Bluetooth headphones or speakers, but it cannot receive Bluetooth audio from a phone or other device.
Can DAP Neo play DRM-protected files?
DRM-protected songs require copyright verification for playback. Playback will fail without successful verification, and this is a standard limitation for all DAPs.
How long does the battery last?
According to tests, the DAP Neo has a maximum battery life of 12 hours. Actual battery life varies depending on settings and playback conditions.
Does DAP Neo support gapless playback?
Gapless playback is not available on DAP Neo.
How do I skip tracks?
DAP Neo is operated using physical buttons and a click wheel; It does not support touch input. When the screen is locked, use the center button to control playback:
- Press once: Play/pause.
- Press twice: Next track.
- Press three times: Previous track.
