Overview Specs In the Box Compare
★★★★★ 4.6 (64 reseñas)
Nano White
$99.99
 Small in Size. Big on Music.
All the fun of playing real CDs, without the bulky setup. Just 102mm across, with Bluetooth listening through your favorite headphones or speakers.
Fosi AudioFosi Audio
See Your Music Spin.
The spinning CD takes center stage again. Every press of Play
becomes something you can see and feel.
Music That Fits Your Space.
Magnetic placement lets the player fit naturally on your desk, in the kitchen, or in
your music corner. Keep your music close without giving up extra space.
Less Skipping. More Listening.
A little movement shouldn't interrupt your favorite track. ESP electronic anti-shock
helps reduce skipping for a smoother listening experience.
Everything at a Glance.
See the ports,controls,and box contents in one place.
Product Specification
Audio DAC Chip Cirrus Logic CS43198
Output Interface 3.5mm Headphone/Optical Combo, 4.4mm Headphone
Compatible Headphone Impedance 16–300Ω
Max. Headphone Output Power L+R ≥86mW+86mW (32Ω, THD+N <1%)
Signal-to-Noise Ratio ≥100dB
Supported CD Formats CDDA, CD-R/CD-RW (partially readable), SACD with CD layer
Battery Capacity 800mAh
Charging Port USB-C
Input Voltage 5V/1A
Dimensions 102 × 102 × 29mm
Weight 210g
 Does DISC Nano support MagSafe wireless charging?
No. DISC Nano features a MagSafe-compatible magnetic design for mounting only. It does not support wireless charging. Charging is handled through the USB-C port.
 How do I connect DISC Nano to Bluetooth headphones or speakers?
Play a CD, then press the Mode button to enter Bluetooth mode. Set your headphones or speaker to pairing mode and keep it close; DISC Nano will try to connect automatically. If it connects to another device, press and hold Mode to clear the pairing. DISC Nano sends audio to Bluetooth devices but cannot receive audio from a phone.
 Can I connect DISC Nano to an external DAC?
Yes. DISC Nano features a 3.5mm headphone/optical combo output. Using a compatible 3.5mm optical (Mini-TOSLINK) cable, you can send digital CD audio to an external DAC with an optical input. The same jack also supports regular 3.5mm wired headphones.
 What types of CDs does DISC Nano support?
DISC Nano supports standard audio CDs (CDDA), selected CD-R/CD-RW discs, and the CD layer of hybrid SACDs. CD-R/CD-RW compatibility may vary depending on the disc and recording conditions. Original pressed audio CDs are recommended for the most reliable playback.
 Does DISC Nano support USB music playback or CD ripping?
No. The USB-C port on DISC Nano is for power and charging only. It does not support USB music playback, data transfer, or CD ripping. If you need USB playback or CD ripping, the Fosi Audio Merak CD Player supports both features.
Customers praised the compact CD player's "audio perfection" and elegant design, with many noting "top notch" sound quality and reliable Bluetooth connectivity. The visible spinning disc is beloved. However, some shoppers reported Bluetooth pairing issues and lack of gapless playback for certain albums. Battery life (~2h) was noted as short.
  • 5 stars: 42 (66%)
  • 4 stars: 17 (27%)
  • 3 stars: 4 (6%)
  • 2 stars: 1 (2%)
Che (Puerto Rico)
Love it,
Been a CD fan since 1990s , this is so cool, great sound =, mine is white and is awesome
Joshua (United States)
Amazing Little Device
I absolutely love my little Fosi Nano. It’s beautifully made, had outstanding sound, and I love the fact that it’s magnetic and can be used untethered with its built-in battery.
It’s not perfect: I miss a remote control, a true line out, and the skip forward and back response is slow, but that only forces you to be a bit more intentional. It’s best if you just put on a CD and listen to the entire thing. And that’s kind of how it should be.
Owen (United Kingdom)
Fantastic player
I have recently changed over to Fosi, I have purchased 6 fosi hifi separates and have been totally floored with the quality & sound coming out of these components, the latest purchase was the fosi nano CD player, I have used it as my bluetooth CD and it has lived up to the same level as all the other fosi components, very pleased with this purchase based on sound and build
Ethan (United Kingdom)
Beautiful. Small. Perfect sound. Optical out. Can’t ask for more!
DAVID (Colombia)
Excellent functionality, with some caveats
It would be a 5-star review, but let me start with what I liked most. The CD reader is excellent; it seems to cope very well with the somewhat scratched CDs I have. I remember the audio on them skipping or jumping in other players. The lid is made of glass, which is nice, but the chassis is plastic; I was hoping for aluminum instead. Still, the aesthetics are nice.
The USB port is only for charging. I don’t mind this—I wanted a straightforward CD player—but if you plan to rip/archive copies of your CDs, I suggest buying one with that capability, or a separate standard external CD/DVD drive along with the free, feature-rich Exact Audio Copy program.
It has the must-haves: a mini-optical output, so you can process the raw audio signal with an external DAC, and a 4.4 mm balanced output. That makes life easier if you have IEMs with this plug, saving you some hassle.
The reason for 4 stars: the back, which holds the magnetic pad, came with weak glue. Fortunately for me, it was standing vertically but not far from the surface; the pad came off and the player fell. I used stronger glue.
The CD player loops automatically: once the last track finishes, it starts the CD over. There is no way to disable this—or perhaps I just didn’t find it.
Dani (Colombia)
consulta soibre un pedido no ha llegado informacion al correo
consulta soibre un pedido no ha llegado informacion al correo es el pedido de un amigo no mio
Matthew (Australia)
Almost perfect
Just what I was looking for
A wireless cd player I could use in my car
added bonus it looks super cool as well.
I think mine may be faulty though as the battery does not last nearly as long as I was lead to believe.
3.5 audio jack also does not work flawlessly with my headphones.
things I would change, either wireless charging or hot swappable AA batteries.
I would also like it if I could have the cd stop after one listen through rather than auto repeat.
I still love it though and would recommend to others
Anonymous (Portugal)
Adorei a versatilidade, praticidade, design, a conectividade e principalmente a qualidade do som, recomendo 🙌
John (United States)
Marvelous
Does what it is supposed to and does it perfectly. Love watching it spin. Zero issues with scratching or “cutting” anything.
JazzPirate (United States)
Excellent CD player!
Works very well. Connects easily with bluetooth to my Fosi amp. Internal power supply for wire free connectivity. Very well thought out and implemented. Another great product from Fosi!
Rob (United Kingdom)
Great nano size portable CD player!
Love this nano size cd player👍
It is a cool piece which all the functionality one requires, solid build too.. 👊
Ferran (Spain)
Great concept, some flaws
The player is really cool, I would keep it if:
- it was gapless
- battery lasted more than 2h
I also suggest:
- option to rotate display orientation
Don (United States)
Cute piece of must-have nano-tech
My expectations were limited – what should I expect for $100? But I'm blown away with its audio perfection and clever, elegant design.
No trouble with Blue Tooth. Paired instantly with my Airpods2.
I'm buying several more for Xmas presents.
Roy
Rediscovering My CD Collection
I've been collecting CDs for years, and it's nice to have a reason to pull them off the shelf again. Streaming is convenient, but there's something satisfying about choosing an album and listening to it from beginning to end. The DISC Nano's design makes the experience feel a little more special.
Efrain
Perfect for a Small Space
A compact setup is always a plus, especially in a bedroom or on a smaller desk. There's no need for a dedicated audio rack or tons of space. Just keep in mind that the open disc lid needs a little extra room.
Maksym (United States)
Good device with new technology
I like the small player, especially Bluetooth. I can connect with my smart home or my headphones
Duane (United States)
Fun and Unique little player
I really like the form factor. It seems to have all the options you would ever need. Sounds great and I love that it has an internal battery.
Andrea
Tutto bene
Ryu (South Korea)
디자인, 그 하나만으로 모든 것이 용서되는 제품입니다
디자인, 그 하나만으로 모든 것이 용서되는 제품입니다. 가격이 매우 합리적이고 무조건 별 다섯개입니다.
JAQL (United States)
Fosi nano review
Fantastic device. I’d complain about the battery life or the non-gapless playback but I’d also be lying if I gave this any less than 5 stars. My new favorite device for listening to music.
Wesley (United States)
Solid construction and fun to use
I love the solid construction of the Disc Nano, it is even smaller than I expected to be and the materials used are great. I was not expecting the lid to be glass but it is a really nice touch. The soud quality is good as well however I wish there was a little more tone, the sound is somewhat thin and shrill with the headphones and IEM's I have tested it with.
Bryce (United States)
Beautiful, Garbage Sound
Looks so good...
But the audio is garbage. Wired is OK but forget about bluetooth, hissy chopped highs, sounds like a 128k mp3. really really disappointed. I hope they can fix this via firmware. Buy it for the looks, skip it for the sound.
Zane (Australia)
retro is back
awesome retro product from Fosi who just keep innovating like crazy, keep up the great work guys!!
Philippe
Étonnant petit lecteur de CD.
Permet de redécouvrir mes CD des années après.
Le délai de livraison est un peu long, l’appareil partant directement de Chine.
Mais cela vaut l’attente.
Rafael (Finland)
Una Maquina excelente. Gracias
